07-20-2007, 06:59 PM | #21 |
Well, technically, the TLT doesn't use steel gears either It's that cruddy pot metal and I managed to blow through a set of the TLT gears my first time out... I had to shim 'em just like the PTI gears to keep 'em from stripping.
07-20-2007, 07:03 PM | #22 |
Rock Crawler Join Date: Apr 2007 Location: portland
| thats nice . that comment makes this mod even more worthless. makes it like swapping garbage with different garbage. awsome |
07-20-2007, 07:14 PM | #23 |
Well, it never hurts to try something different. Neither gears are junk exactly. We're using them for things they weren't really meant for, so you gotta do some mods to make it work. Although, the way things are progressing now, that is becoming less and less the case.
07-20-2007, 09:48 PM | #24 |
Newbie Join Date: Aug 2006 Location: everson
hey i try to help out a little and you people are actin like a**es if you think its worthless then dont post up about it just dont use it. it was a little mod i though i would try if it worked thats good but if not then it dont use it if you want just dont flame me for trying to help out
07-20-2007, 10:19 PM | #25 |
and im sorry about the blury pics i have a really old cam that works on taking pics of people but when you try to take close ups of stuff like that it sucks so i will try to get better pics here soon
07-20-2007, 11:06 PM | #26 |
Quarry Creeper Join Date: Jul 2006 Location: In a tree top with my chainsaw!!
pics would be good, results of testing would be better. I need to buy all new internals for my goliath axles, and if this mod is going to work, I would like to try it as well. and pti axles are not garbage, they just need upgrades. TLT's are pretty much junk unless you put a ton of money into them. I can't wait to get my goliath running again.
07-20-2007, 11:12 PM | #27 | |
Rock Crawler Join Date: Apr 2005 Location: Upland
Have you ever ran the PTI axles? If you shim them right (like you're suppose to) they won't strip that easily. Besides it's better to break or strip something easily obtainable and cheap. The PTI ring gear is an Associated part that you can find almost anywhere. Just thought I'd let you know. | |
07-20-2007, 11:18 PM | #28 |
RCP Crawlers makes a brass alloy ring and pinion gear set for the TLT. That would be a good alternative to the stock axle pinion... if this mod works. I'm curious to see some results. I don't put down the mod, I like it when people think outside the box. I've had people tell me something won't work or it can't be done, only for me to prove them wrong (that's one of the reasons I designed the original MMT?). So the more mods the better. |
07-20-2007, 11:23 PM | #29 |
wow I did not know that you had designed the MMT. that is awesome. I bought the original goliath before the crawler version came out. Like i said, I can't wait to get it running.
07-21-2007, 03:24 PM | #30 | |
07-21-2007, 09:57 PM | #31 |
i have a set of tlt axels but im waiting for my tuber to get done for it and im using the pti axels for a scaler anyways so im not going to be putting them under alot of stress and i am working on making a metal ring gear fit on the pti spool so once i get it figured out i will post it up 2 but i cant ruin all my susprises yet but like i said i will post it up once i get it to work
