Thread: PTI Axle Build
Old 09-09-2007, 03:45 PM   #1
Default PTI Axle Build
I ordered a PTI excluding the parts I wasn't going to use and here is what I got.
Mike Poulson is offline   Reply With Quote
Old 09-09-2007, 03:57 PM   #2
To address the loose pinion\input shaft bearings I sanded the housings with some worn out 80 grit on a nice flat piece of hardwood, applying pressure at the area of the pinion shaft bearings. It will have just a slight taper, trying not to take as much material off the rest of the housing but nice and flat. Sand until the bearings fit tight.
Next I drilled through the housing screw holes so the screws wouldn't bottom out and strip, and allow a 4-40 x3/8" socket head.
Old 09-09-2007, 04:07 PM   #3
I am going to use all Associated parts so to use the TC3 steering knuckles I am going to fit a 1/4" piece of round aluminum in the axle with a .111" hole in it.
The axle housing is .230 and needs to be enlarged. At the same time I need it to extend out more so the CVD's fit better.
Here is a pic that shows it on paper.
Old 09-09-2007, 04:14 PM   #4
First I extend the hole to .250" dremel or file making an oval shape, then work the sides to about .245" or so the I used a 1/4" round file to finish the hole and make it round. It need to be a nice tight press fit.
Old 09-09-2007, 04:18 PM   #5
I made some 1/4 x 1/8 busings with a .111 hole and pressed them in the housings.
Old 09-09-2007, 05:28 PM   #6
genius. i will be watchin this one.
danielk is offline   Reply With Quote
Old 09-09-2007, 09:30 PM   #7
The housings are ready to be put together. I built MIP drives using B4 stub axles and RC10/B2/B3 bones.
Lubed and thread lock the joint per MIP instructions.
Assembled the steering block per Associated instructions, making sure to use the crush tube between the bearings. Because of the way the hex is installed it will have the pressure from tightening the wheel on it.
I like to cut a new slot on the flat side of the hex, at first I used a 1/16" drill bit it's a lot of work. Then bought a 1/16" ball mill bit and milled them.....much better.
2 thick MIP shims then the hex and fit the 1/16" pin in last.
For a wider width 1 crush tube 2 thick shims the pin and then the hex.
The roll pins that come in Associated kits and MIP drives to secure the hexes don't hold up to crawling stresses and break real soon. I cut pins from 1/16" piano wire.
Old 09-09-2007, 09:43 PM   #8
I could only find 1704 nitro spools, I cut them down to the 1703 electric size, the slot for the cross pins on the spool out drives need to be in just past the bearing so the bone will fit deep. Also the cross pins on the bones are a little wide, I grind them down even with the spool out drive.
Old 09-09-2007, 09:52 PM   #9
I found that shimming the gears is not needed the gear mesh, bearing preload on the spool and backlash for these parts is slightly tight.
The area on the back side of the pinion between the bearing is a good place to adjust the gear mesh, usually just cutting the bumps and flashing off the pinion gear moving the pinion out, will be just right.
Old 09-09-2007, 10:03 PM   #10
I bolted the housings together with 10 4-40x3/8" socket head screws.
I needed a little clearance to get more steering angle on the front. Cutting some of the housing and some from the steering arm.
I spent a couple of weeks messing around with the first axle build, I was able to duplicate the second one in 3 hours.
Old 09-09-2007, 11:03 PM   #11
Nice!!
I like how you clearanced the c's and the insides of the knuckles.
CVDs seem like they would be invincible.
mxdomzy is offline   Reply With Quote
Old 09-10-2007, 02:06 AM   #12
K_B
Aren't you the same guy that made those crazy high-clearance axles with TC3 diff cases? I was hoping you'd do something with these axles.
K_B is offline   Reply With Quote
Old 09-10-2007, 08:10 AM   #13
Yes, I make those crazy high clearance axles I am thinking of making a scale rig and needed some quality axles. These PTI axles use all the same parts as my comp rig, so that will be cool.
A set of my high clearance axles made it the top 5 at the Nats
MikeP
Old 09-10-2007, 04:46 PM   #14
K_B
I just noticed that! Congratulations! I love how everyone talks about how easy the gears strip and yet, they held together well enough for a top 5 finish at Moab.
Looks like I need to go shopping for some CVDs now.
Old 09-10-2007, 05:15 PM   #15
Maybe I missed it, but what cvd's did you use?
jdawg53 is offline   Reply With Quote
Old 09-10-2007, 10:06 PM   #16
RC10\B2\B3 bones with B4axles
Old 09-10-2007, 10:14 PM   #17
So the CVDs listed are not a direct fit. Right?
aggressivellc is offline   Reply With Quote
Old 09-10-2007, 11:16 PM   #18
Right, for the steering knuckles I used they were just a tad long.
Old 11-18-2007, 06:23 AM   #19
666
MODERHATER™
666's Avatar
Any updates on this build?
666 is offline   Reply With Quote
Old 11-20-2007, 08:04 AM   #20
No updates, been looking for parts to build a trail rig but nothing yet.
Mike
