12-28-2011, 09:35 PM | #21 | |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
| Re: Turtle's Modified TB01 Quote:
Well now you have two rally cars. | |
12-28-2011, 09:47 PM | #22 |
Rock Stacker Join Date: Jan 2011 Location: QNZ 11377
on the first pic the chassis has a cover for like dirt rye? where did you get that?
12-28-2011, 09:52 PM | #23 |
DOOH!!! Join Date: Feb 2007 Location: AZ
| Re: Turtle's Modified TB01 |
12-28-2011, 09:58 PM | #24 | |
You got a couple more cars to get, a ton of tires, wheels and spare parts to go. | |
12-29-2011, 08:00 AM | #25 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
12-29-2011, 08:29 AM | #26 |
12-29-2011, 09:20 AM | #27 |
I wanna be Dave Join Date: Dec 2008 Location: ?
Ty Does the DF-03RA and the TB01 use the same wheel base for body's? |
12-29-2011, 10:18 AM | #28 |
12-29-2011, 11:38 AM | #29 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
Turtle you need to let me win one of those rally's |
12-29-2011, 12:09 PM | #30 |
01-02-2012, 08:35 AM | #31 |
Here's a idea I found to help with Dirt. Should be some what easy to make. |
01-02-2012, 08:41 AM | #32 |
01-02-2012, 09:15 AM | #33 | |
But because the chassis is open on the bottom of the motor Rodney got some associated chassis protector to cover the hole under the motor. The hole would help with cooling, but water splashes into the chassis there and the foam piece gets soaked and stays wet. Now that the hole is covered it keeps everything out, now checking temperatures is going to be a little bit more important with the inclosed environment the electronics are in. | |
01-02-2012, 09:17 AM | #34 |
Got a part number for that cover?
01-02-2012, 09:37 AM | #35 | |
I was thinking that was a big ol' honkin' hole in the chassis. | |
01-03-2012, 01:44 AM | #36 |
Pebble Pounder Join Date: Mar 2008 Location: Salinas gang central of california
wow!!! its nice to see some using that pig for ralley!... its burtally strong i turned my subie prototype into a drifter.. the only week point in the car i have seen is the cassis. that it flexs to point that it chews on the plastic drive shaft gears. but if you get a ralley kit and run all the metal drive line stuff who is gona care about the chassis flex. |
01-03-2012, 12:42 PM | #37 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
The TB01 was an onroad car before aimed at Rally (at least 90% of its parts), so it drives and sets up like an on-road car. Makes setting it up easier. The DF03ra is a 4wd buggy with narrow arms, its needed set up is very different than that of an on-road car. Both nice chassis's though so you can't go wrong either way. I just prefer ball diffs to gear diffs. |
01-03-2012, 06:55 PM | #38 | |
Actually 90% of the parts came from the Nitro TGX, to the TB01, yes it was built to be a car, but it was quickly realized it was more suited to be a rally car then a touring car, which is why it comes with front buggy shocks. Because of the TB01s fate Tamiya made the TB02, TB03, TB04,and TB05 which are on road specific vehicles. Granted the TB02 has some characteristic suited for rally the TB01 is a better platform. The reason the TB01 lived for nearly 10 years is because of rally. The DF03RA is not just narrow A arms, but actual touring car arms with TT01 dog bones, shock towers, shocks, smaller spur gear cover, smaller spur, etc. As I have said before if you put a brushless motor to the ball diffs of the DF03RA you will melt the rear diff down, no way around it. There may be more tuning available for ball differentials, but they can not handle the power like a gear diff can. I know because I have gone through several diffs as have several people I know who have DF03RAs. If you read the threads You would notice I have said all of this before. You may have ok luck with the ball diffs, but drive it a couple times a week for a couple years with a 5700 or 3500kv motor and let me know how it works out. Both are solid and durable platforms once properly modified, but really there is not much comparison, when you are looking to build something tough enough to take the abuse of rally and still have really good handling characteristics. The TB01 is a better driving car and just as durable, if not more. There are no two ways about it. | |
01-09-2012, 09:11 PM | #39 |
RCC Addict Join Date: Apr 2006 Location: Brighton
Really impressed with the stoutness of this kit, just buttoning up the last few details and fiddly things on my 1st tb-01. Thank you for the tips and some hints as I was building TY I think I missed one thing in my parts order...the sway bars Already got a traction roll or 2 out of the way...good thing I had a beater touring car body on it Can't wait for the lipo packs to arrive. |
01-09-2012, 09:49 PM | #40 |
No worries Stan. Mine still traction rolls even with the sway bars, but it is a little bit better. If the bend was not so complicated I would have made a couple different thicknesses to try out already. Maybe when I am not being lazy I will make some.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/rally/354210-turtles-modified-tb01.html | ||||
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - Querendo começar no Rally | This thread | Refback | 02-20-2013 09:13 AM |
Turtle's Modified TB01 - Similar Threads | ||||
Turtle's Modified DF03ra | TURTLE | Rally | 83 | 04-10-2014 02:38 AM |
Turtle's Splatterness | TURTLE | Paint and Body | 97 | 02-28-2014 10:56 PM |
