08-23-2016, 02:45 PM | #1 |
Rock Crawler Join Date: Apr 2013 Location: Buena Vista
| Bvrc's MST XXX Rally
This is my first MST car. Wheelbase : Standard 257mm (adjustable) Width : Standard 186mm (adjustable) Gear ratio : 5.54~9.22 Caster : 6 degrees MST's XXX Rally page Last edited by bvrc; 08-24-2016 at 05:37 PM. |
08-23-2016, 06:39 PM | #2 |
| Re: Bvrc's MST XXX Rally
Interesting... MST is using Tamiya bodies on these things... ... Edit: Now that I'm actually looking at MST stuff it seems like they use Tamiya bodies on multiple rigs, not just these rally cars. Last edited by bvrc; 08-24-2016 at 09:59 AM. |
08-24-2016, 09:51 AM | #3 |
The transmitter seems to work fine, but feels very cheap. It has something loose inside... It feels like one of those little cans that moos like a cow when you turn it over... Last edited by bvrc; 08-24-2016 at 09:57 AM. |
08-24-2016, 09:59 AM | #4 |
The manual is very basic; totally functional, but not the best. It's an RTR so there's not much in the way of instructional steps... One of the only things it tells you to do is cut this little plastic corner off. I can't really figure out why. Last edited by bvrc; 08-24-2016 at 10:03 AM. |
08-24-2016, 10:15 AM | #5 |
I really like the stance it has out of the box. It's a bit taller in the front and a bit shorter in the rear. Love the gull-wing arms! Last edited by bvrc; 08-24-2016 at 10:19 AM. |
08-24-2016, 10:20 AM | #6 |
The suspension travel is badass. The shocks feel great; extremely smooth out of the box. When you drop the chassis on the bench, the front has a bit of bounce back. It actually looks nice and scale but I might try some heavier fluids in the front shocks. Spring rate seems good for the stock weight. Last edited by bvrc; 08-24-2016 at 10:28 AM. |
08-24-2016, 10:42 AM | #7 |
I plugged a pack in and realized the the gear mesh was horribly loose. Then I noticed the motor was pretty loose as well... The upper chassis brace makes getting to the motor a bitch. Lessons learned... It's always fun discovering the quirks of a new chassis. Last edited by bvrc; 08-24-2016 at 10:51 AM. |
08-24-2016, 11:22 AM | #8 |
| Re: Bvrc's MST XXX Rally |
08-24-2016, 12:34 PM | #9 |
After one pack. Fun little car! |
08-24-2016, 04:03 PM | #10 |
The rtr servo isn't too terrible, but I'm used to a bit more speed... Savox 1258 it is... Both the stock servo and the savox use a 25t spline. So I just put the stock servo saver on the savox 1258. Last edited by bvrc; 08-24-2016 at 04:14 PM. |
08-29-2016, 09:13 PM | #11 |
Newbie Join Date: Oct 2010 Location: Littleton
Did you get that on eBay?
08-30-2016, 05:18 PM | #12 |
| Re: Bvrc's MST XXX Rally Last edited by bvrc; 08-30-2016 at 09:50 PM. |
08-31-2016, 10:53 AM | #13 |
Newbie Join Date: Aug 2016 Location: Saint-Petersburg
Very interestings chassis. How it's comparied to xv-01 ? To the first sight, looks like TT-02. Does it have diffs like xv-01 ?
08-31-2016, 08:04 PM | #14 | |
| Re: Bvrc's MST XXX Rally Quote:
The XXXR comes with ball diffs front and rear as opposed to the xv-01 that uses gear diffs. This gear diff should work on the XXXR ... | |
09-01-2016, 03:20 PM | #15 |
09-01-2016, 07:55 PM | #16 |
The car from left to right... XV-01 with a VW polo R from monkeyracing.cz. ... Rallylegends chassis with a fiat body .... MST XXXR
09-02-2016, 01:19 PM | #17 |
Thanks, which chassis do you like best and why?
09-02-2016, 04:57 PM | #18 |
| Re: Bvrc's MST XXX Rally XV01 for sure. I know it the best. I have multiple xv01s and lots of parts. I can diagnose problems quick. Also, most of my buddies run them which is always nice... The MST is new for me. I like it a lot so far. Excluding bigger cars like DRX and WR8, the MST is the best RTR rally kit out there. No doubt about that. It's a competitive little car for our style of racing. And it's only $300 RTR... |
09-26-2016, 06:59 PM | #19 |
Pebble Pounder Join Date: Jan 2014 Location: Reynoldsburg
I'm thinking of getting this. I've owned two xv's, a pro and a long damper kit. Would this feel like a downgrade and do you think the ball diffs are functional? Sent from my LGLS990 using Tapatalk |
09-28-2016, 09:42 PM | #20 | |
Overall this car is really nice. I wouldn't call this car a downgrade from an xv01. It's certainly different though. | |
Bvrc's MST XXX Rally - Similar Threads | ||||
BVRC's CRC XV-01 | bvrc | Rally | 218 | 06-21-2021 10:31 AM |
Bvrc's scx10 II | bvrc | Axial SCX10 II | 7 | 06-22-2016 08:27 PM |
BVRC's YetiXS | bvrc | 1.9 Scale Rigs | 15 | 05-04-2015 08:39 AM |
BVRC's XV-01 Drifter | bvrc | Non Crawler RC's | 2 | 08-28-2014 07:25 PM |
XXX-S converted to XXX-Rally | bnoland | Rally | 10 | 09-01-2008 07:37 PM |
