08-23-2017, 10:21 AM | #21 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: I bought a Associated Pro Rally
I'm having problems with the fan on the Esc cause sometimes it rattles at start up and at shut down like its going out, and its loud some times and if you screw with it, it gets quiet for a little while then makes noise again and It acts just like the fan in my desktop that I had to replace cause it stopped working, and it rattled before it stopped working Need to look for a replacement fan for Esc, I have ran it around my house with out the body and it does run a little warm, its hotter with the body on, I'm going to Shoo Goo and drywall tape the entire body And was thinking about cutting out the drivers side and passenger side windows, to add airflow then and use some screen to keep debris out, so with the new Esc fan and vented windows that should make it run cooler Unless it normal runs a little runs warm Last edited by kgb424; 08-23-2017 at 10:28 AM. |
12-12-2017, 05:14 PM | #22 |
I called the Team Associated repair service line and they do not have replacement fans for the #29138 XP SC500 BL ESC's cause the Rally and Pro SC have been discontinued already, that sucks cause I have only used it once or twice cause of the bad fan But any 5volt .05amp to .10 amp 25mm x 25mm x 10mm square fan would work as a replacement Going to look online and see what I can find, I remember my old AMD CPU's used to a Super Cooler than that was better than a normal fan of the same size Maybe I can get lucky and find a CPU fan or good quality no made in China fan |
12-15-2017, 12:32 AM | #23 |
I got lucky and this kinda of stuff happens to me alot, when you have RC stuff stashed everywhere Cause I found 3 Novak 25mm X 25mm X 10mm fans in a drawer, I cut the connector off the dead fan And soldered and shrink tubed the new fan wires and have two more fans for spares Last edited by kgb424; 01-09-2018 at 06:35 PM. |
I bought a Associated Pro Rally - Similar Threads | ||||
Losi Rally Pro 4 + Traxxas rally wheels | jeepgeek2002 | Rally | 1 | 01-05-2015 06:10 AM |
Bought a MRC pro!! | rockcrawler150 | Losi Mini-Rock Crawler | 13 | 07-17-2011 03:41 PM |
Just bought a MacBook Pro | srfrkyle1234 | Chit Chat | 15 | 06-14-2007 04:09 AM |
