Go Back   RCCrawler Forums > Miscellaneous > Rally
Thread: Slipper spur
Old 09-18-2017, 02:20 PM   #1
Default Slipper spur
Where can you buy just the gear for a slipper set up? Tried Google but no luck, just comes up as the hole kit. And do any others work?
BIKETROLL is offline   Reply With Quote
Old 09-18-2017, 02:22 PM   #2
Default Re: Slipper spur
Sorry it's a xv01
Old 09-22-2017, 09:58 AM   #3
I use an Associated spur with Associated pads.
Blaster 75 is offline   Reply With Quote
Old 09-27-2017, 02:55 AM   #4
What parts numbers please, if you remeber
arthx is offline   Reply With Quote
Old 10-02-2017, 11:29 AM   #5
Associated 9648 (spur), Associated 91170 (high torque slipper pad), Associated 9603 (standard slipper pad). You can use pretty much any octagonal slipper pad, though.
Old 10-03-2017, 04:43 AM   #6
Thank you
Old 10-15-2017, 02:59 PM   #7
look up Tamiya - 54219
77 tooth comes as module 48dp and suits also the TRF201
perfect match.
Dims is offline   Reply With Quote
Slipper spur - Similar Threads
Slipper/Spur Help WesTX Axial Wraith 3 11-20-2014 07:09 PM
Non slipper spur retainer Solid94 Axial SCX-10 2 08-25-2014 02:15 PM
Slipper clutch/ spur gear meanbgreen Newbie General 6 09-02-2011 08:20 AM
