My XV-01 After reading turtle's XV-01 thread, I decided to build my own Lancia Delta. It will be a mixed on/off road with two kind of bodies. I have all the pieces (I hope) and I slowly started the building. For the moment I'm at the slipper clutch stage : https://uploads.tapatalk-cdn.com/201...afa8526b3e.jpghttps://uploads.tapatalk-cdn.com/201...984ba4c38d.jpghttps://uploads.tapatalk-cdn.com/201...fad4781468.jpg Sent from my Redmi Note 7 Pro using Tapatalk |
Re: My XV-01 Hey hows the build going? Ive just ordered an XV01 looking forward to building it up Will be stock to start with |
Re: My XV-01 Quote:
I stopped the build for the moment I have to find the "inspiration" [emoji28] I already know that a big headache is waiting for me when I'll have to put electronics in it. Envoyé de mon Mi 9T Pro en utilisant Tapatalk |
Re: My XV-01 Update : after changing the position of the engine and successfully tested the electronics (which gave me a headache [emoji856]), I mounted the wheels on the chassis and made a little driving test. Unfortunately I cannot understand why the car behaves like a traction, I have 0.001% propulsion on the rear axle. I checked the belt and the pulleys and everything seems OK, but as soon as there is any resistance (just a finger on the rear tires) I have no power in the back. Do you have any hints? I thought of a big difference of oil in the gears of the differentials (I forgot the references but basically more dense in the front)https://uploads.tapatalk-cdn.com/201...b826237f4a.jpghttps://uploads.tapatalk-cdn.com/201...72b0018946.jpghttps://uploads.tapatalk-cdn.com/201...bb2191908d.jpg |
Re: My XV-01 Sounds like there is a cross pin missing somewhere..... |
Re: My XV-01 Quote:
Re: My XV-01 OP you're off to a good start, looking forward to more rally goodness! :) Quote:
Re: My XV-01 I found: the two pulleys tended to get loose because I had not pressed the two plastic pieces NN24 and 13 enough (it was so hard that I thought I'd break them). Thus there was no place to properly insert the circlip in his seat: as there was traction the exagon of the pulley came out of the small iron pin BA and therefore no more traction. Now I have tightened plastic pieces but I hope that the two e-rings will hold (I folded and covered with glue once installed). Thank you all for your advices ... I will surely bother you again ... Now I'm fighting with the servo direction that I can not adjust correctly ( too much right or left [emoji28])https://uploads.tapatalk-cdn.com/201...b02358703b.jpghttps://uploads.tapatalk-cdn.com/201...6455026fa4.jpghttps://uploads.tapatalk-cdn.com/201...83dff4dc96.jpg |
Re: My XV-01 |
Re: My XV-01 Reinforcing the body with shoegoo and aluminum tapehttps://uploads.tapatalk-cdn.com/201...9e49a89530.jpg |
Re: My XV-01 Decalshttps://uploads.tapatalk-cdn.com/201...e13f5f2e39.jpghttps://uploads.tapatalk-cdn.com/201...89b4ca36f3.jpghttps://uploads.tapatalk-cdn.com/201...25d5337292.jpghttps://uploads.tapatalk-cdn.com/201...41a4b55f6c.jpghttps://uploads.tapatalk-cdn.com/201...5afb2c4178.jpg https://uploads.tapatalk-cdn.com/201...61556658f2.jpghttps://uploads.tapatalk-cdn.com/201...efddb9f1c7.jpg |
Re: My XV-01 |
Re: My XV-01 |
Re: My XV-01 |
