12-21-2019, 04:35 AM | #1 |
Newbie Join Date: Apr 2013 Location: Burgess Hill, UK at the moment
| XV01 advice requested excessive play in the counter gear/slipper shaft
Hi all, I’m building up my XV01 and I noticed the spur gear has a lot of side to side movement. I had installed the slipper clutch so I disassembled and reassembled double checking to make sure I hadn’t missed any shims (I hadn’t). I checked again and got the same thing, close to 2mm of side to side play for the whole slipper shaft assembly. That feels like too much to me. So I disassembled and reassembled using the stock parts, same thing close to 2mm side to side movement of the whole shaft. Is that normal in an XV01. I’m used to maybe 1 millimeter of play. Did anyone else have the same experience? Did you leave it? Or did you have to shim it? Thanks in advance for your input. GK |
12-26-2019, 09:00 AM | #2 |
Rock Stacker Join Date: Apr 2014 Location: Las Vegas
| Re: XV01 advice requested excessive play in the counter gear/slipper shaft
I don’t know if it’s normal as I don’t run the slipper. My advice is to shim, always shim
01-04-2020, 10:14 AM | #3 |
Thanks, I shimmed.
XV01 advice requested excessive play in the counter gear/slipper shaft - Similar Threads | ||||
Ascender Interior Advice Requested | cen0 | Vaterra Ascender | 8 | 03-24-2015 07:30 AM |
Advice requested planning a budget SCX10 jeep kit build | theTman | Axial SCX-10 | 41 | 11-21-2014 01:14 PM |
Drive gear shaft has play in it | robertjpjr | Axial SCX-10 | 9 | 12-08-2013 11:23 PM |
