Go Back   RCCrawler Forums > Miscellaneous > Rally
Thread: Bvrc's MST XXX Rally
Old 08-23-2016, 02:45 PM   #1
Default Bvrc's MST XXX Rally
This is my first MST car.
Wheelbase : Standard 257mm (adjustable)
Width : Standard 186mm (adjustable)
Gear ratio : 5.54~9.22
Caster : 6 degrees
MST's XXX Rally page
bvrc is offline   Reply With Quote
Old 08-23-2016, 06:39 PM   #2
Default Re: Bvrc's MST XXX Rally
Interesting... MST is using Tamiya bodies on these things... ... Edit: Now that I'm actually looking at MST stuff it seems like they use Tamiya bodies on multiple rigs, not just these rally cars.
Old 08-24-2016, 09:51 AM   #3
The transmitter seems to work fine, but feels very cheap. It has something loose inside... It feels like one of those little cans that moos like a cow when you turn it over...
Old 08-24-2016, 09:59 AM   #4
The manual is very basic; totally functional, but not the best.
It's an RTR so there's not much in the way of instructional steps... One of the only things it tells you to do is cut this little plastic corner off. I can't really figure out why.
Old 08-24-2016, 10:15 AM   #5
I really like the stance it has out of the box. It's a bit taller in the front and a bit shorter in the rear.
Love the gull-wing arms!
Old 08-24-2016, 10:20 AM   #6
The suspension travel is badass.
The shocks feel great; extremely smooth out of the box.
When you drop the chassis on the bench, the front has a bit of bounce back. It actually looks nice and scale but I might try some heavier fluids in the front shocks.
Spring rate seems good for the stock weight.
Old 08-24-2016, 10:42 AM   #7
I plugged a pack in and realized the the gear mesh was horribly loose. Then I noticed the motor was pretty loose as well...
The upper chassis brace makes getting to the motor a bitch. Lessons learned... It's always fun discovering the quirks of a new chassis.
Old 08-24-2016, 11:22 AM   #8
Old 08-24-2016, 12:34 PM   #9
After one pack.
Fun little car!
Old 08-24-2016, 04:03 PM   #10
The rtr servo isn't too terrible, but I'm used to a bit more speed...
Savox 1258 it is...
Both the stock servo and the savox use a 25t spline. So I just put the stock servo saver on the savox 1258.
Old 08-29-2016, 09:13 PM   #11
Did you get that on eBay?
singletracksean is offline   Reply With Quote
Old 08-30-2016, 05:18 PM   #12
Rcmart.Com
free shipping =)
Old 08-31-2016, 10:53 AM   #13
Very interestings chassis. How it's comparied to xv-01 ? To the first sight, looks like TT-02. Does it have diffs like xv-01 ?
Fletchru is offline   Reply With Quote
Old 08-31-2016, 08:04 PM   #14
It is hard to compare it to the xv-01. I'm really not the best guy to describe driving characteristics of any given car. With that said, I do like the xxxr. I like it a lot. It's definitely different than other cars, but after a few packs it's super fun. Time will tell i guess.
The XXXR comes with ball diffs front and rear as opposed to the xv-01 that uses gear diffs.
This gear diff should work on the XXXR ...
Old 09-01-2016, 03:20 PM   #15
Natedog's Avatar
Originally Posted by bvrc View Post
Nice thread, great looking off-road track, and MST touring/rally car looks pretty nice for the money. Are all three cars in this pic MST or? What is the BMW or ALfa Romeo? Including Tamiya bodies is really great idea on their part.
Old 09-01-2016, 07:55 PM   #16
The car from left to right... XV-01 with a VW polo R from monkeyracing.cz. ... Rallylegends chassis with a fiat body .... MST XXXR
Old 09-02-2016, 01:19 PM   #17
Natedog's Avatar
Thanks, which chassis do you like best and why?
Old 09-02-2016, 04:57 PM   #18
XV01 for sure. I know it the best. I have multiple xv01s and lots of parts. I can diagnose problems quick. Also, most of my buddies run them which is always nice...
The MST is new for me. I like it a lot so far. Excluding bigger cars like DRX and WR8, the MST is the best RTR rally kit out there. No doubt about that. It's a competitive little car for our style of racing. And it's only $300 RTR...
Old 09-26-2016, 06:59 PM   #19
I'm thinking of getting this. I've owned two xv's, a pro and a long damper kit. Would this feel like a downgrade and do you think the ball diffs are functional?
Sent from my LGLS990 using Tapatalk
cullen colapietro is offline   Reply With Quote
Old 09-28-2016, 09:42 PM   #20
I don't have good luck with ball diffs in rally cars... Last night I ordered the gear diffs (part # 21028.
Overall this car is really nice. I wouldn't call this car a downgrade from an xv01. It's certainly different though.
Bvrc's MST XXX Rally - Similar Threads
BVRC's CRC XV-01 bvrc Rally 218 06-21-2021 10:31 AM
Bvrc's scx10 II bvrc Axial SCX10 II 7 06-22-2016 08:27 PM
BVRC's YetiXS bvrc 1.9 Scale Rigs 15 05-04-2015 08:39 AM
BVRC's XV-01 Drifter bvrc Non Crawler RC's 2 08-28-2014 07:25 PM
XXX-S converted to XXX-Rally bnoland Rally 10 09-01-2008 07:37 PM
