| | #1 |
| Tried my very best... ![]() Join Date: Feb 2008 Location: Dortmund, Germany
| Aloha, cann't resist, must have, buy, wait, get, start building, enjoy: ![]() ...to be continued... Greetings from Germany Last edited by Dr.Frank; 06-12-2009 at 04:25 PM. |
| Sponsored Links | |
| | #2 |
| I wanna be Dave Join Date: May 2006 Location: AZ - In The 928
| Post up some specs so there is a little bit of tech. Looks killer though. |
| | #3 |
| ...your're right, tech's missing, so here it comes: Bully 2 axles, for sure (Thanks to RC4WD for quick shipping) JpCustoms Havoc Chassis with 2" skid and brace Double rodended Traxxas Big Bores with black Ansman Springs and filled with 30W oil in the rear 55mm push rods in front (Made off 40mm Lunsford titanium turnbuckles with 4mm treads and Revo Rod Ends, what else) KK high clearance lower Links, also with Revo Rod Ends Robitronic 55T Crawler motors 1" small Tulip aluminum Bead Lock Rims (Made in Thailand, very sweet) Phanter Cougars soft with stock foams (foams are "V" grooved in the middle and a little rounded at the outer edges) What's missing on the list? ...ohh yes, electronics: Tekin FXR, PunkRC Dig, Spektrum RX, 3s 1350mAh 20C Lipo ...and finally JConcepts Rock Steady Single Cab... ...so as i said, to be continued... Greetings from Germany Frank Last edited by Dr.Frank; 06-12-2009 at 04:23 PM. |
| | #4 |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
| Next comes stuffing all your electronics inside...and I do mean stuffing What are those body mounts off of? |
| | #5 |
| ...i know, electronics will have a tight fit Body mounts are FG Stadium Truck 7011/1 Greetings from Germany |
| | #6 |
| OCCUPY RCC! ![]() Join Date: Dec 2005 Location: I am the 53%.
| Off to a nice start Doc! |
| | #7 |
| GOT SCALE? ![]() Join Date: Mar 2008 Location: Scaleville
| great build. Definately making me think about the bully's more. |
| | #8 |
| Black Label Crawlers ![]() Join Date: Sep 2008 Location: behind the wheel of a monster truck...
| You got yourself one awesome looking build going yourself.. |
| | #9 |
| RCC Addict Join Date: Jul 2008 Location: Sin City
| Looks great With the fxr's you shouldnt have a problem getting all the electronics in their easily. |
| | #10 |
| I wanna be Dave Join Date: Jan 2006 Location: Henderson/Las Vegas, NV
| yeah those body mounts, where did those come from? |
| | #11 |
| | #12 |
| Aloha, bulldog made some progress: ![]() ![]() ..lil kitten is not the new driver, just snoopy... ![]() ![]() ![]() ![]() ...inside the "Black Box" under the FXR is a PunkRC Dig, it's boxed because i like neat tidy electronic installation and wireing without any "Havoc". What should i say, "German efficiency" Hot wire arrives today, so i did some programming tonight. ...as you can see, servo's still missing, installation isn't easy, but get some ideas for an solution already. ...to be continued... Greetings from Gremany Frank Last edited by Dr.Frank; 06-18-2009 at 03:36 PM. |
| | #13 |
| Pebble Pounder Join Date: Feb 2005 Location: on a rock in the middle of the ocean
| WOW!!!! That is the cleanest wiring job I have EVER seen, and fitting all of the components on the skidplate is just amazing. Awesome work |
| | #14 |
| | #15 |
| That thing is just SUPER clean! The steering is a nice setup, its amazing how much clearance the bully's give once you get the link above the knuckles. One thing i noticed was your battery placement. Remember the front of the Havoc will flex inward when it articulates so make sure they have room to move. |
| | #16 |
| Rock Crawler Join Date: Jun 2008 Location: Lemont, IL
| small problem with your steering. panthers have very soft sidewalls that like to hook on things that get too cloose(i have been through a couple), in this case, the bolt and drag link. you need to get that tucked down inside the beadlock a bit farther. you may think that it is far enought away, but when the truck gets bound up, the tire will fold over onto that bolt |
| | #17 | ||
Biggest problem is the FXR BEC, with 3s Lipos theres nothing left to come out of the BEC, so i'll have to install an CC-BEC. Greetings from Germany Frank Last edited by Dr.Frank; 06-21-2009 at 11:53 AM. | ||
| | #18 |
| | #19 |
| Hello, it's me again... Have done some practice yesterday evening and a friend of mine took this nice picture of my Rockstar Bully baby: ![]() ...we are planning a little qualification run for the German Super Crawl 2010 in autumn this year and need some public relation pictures. Greetings from Germany Frank Last edited by Dr.Frank; 07-06-2009 at 12:42 PM. |
| | #20 |
| Rock Crawler Join Date: Sep 2008 Location: Utah
| Very nice build, its super clean! That last picture is awesome! |
| Thread Tools | |
| Display Modes | |
