Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > RC4wd Bully
Thread: where to put my lipo
Old 06-27-2009, 06:33 PM   #1
Default where to put my lipo
Well i got my bully up and running. And with all the electronics the only place i can mount my battery is on topof my servo. Whcih i dont mind i like the added weight to the front.
I am running the t chassis full torsion so i can not mount it on the chassis where the links are cause i would lose some suspension travel. Any ideas?
boostedg60rado is offline   Reply With Quote
Old 06-27-2009, 06:34 PM   #2
O so you guys know i also have a 4.0 kamakazie chassis on the way if i dont like the full torsion than i believe it will be easier to mount, .
Old 06-27-2009, 10:10 PM   #3
User Bowtie makes a plate for the rear axle. I put one on mine and am mounting the battery to it. It works very well and he included a velcro strap to mount it.
69CrazyHorse is offline   Reply With Quote
Old 06-27-2009, 11:06 PM   #4
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Yup...get yourself one of Bowties' rear axle plates. Here's mine with a 3 cell lipo.
Offroader5 is offline   Reply With Quote
Old 06-28-2009, 05:57 AM   #5
down in the belly of the chassis is the best place i have found. it allows you to better balance your truck. the rear axle is good also if you run the small 3s lipos but anything bigger should be in the belly.
Culetto is offline   Reply With Quote
