Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > RC4wd Bully
Thread: do losi comp shocks fit bully axles
Old 06-28-2009, 03:48 PM   #1
Default do losi comp shocks fit bully axles
has any one fited and ran the losi comp crawler shocks on there bully axles
smedo is offline   Reply With Quote
Old 06-28-2009, 04:07 PM   #2
Black Label Crawlers
Jeepial's Avatar
Yah they will work just fine with Bully axles..You might have to use a small spacer at the axle as I did to get them clear the gearboxes though.
Jeepial is online now   Reply With Quote
Old 06-28-2009, 04:29 PM   #3
You can run just about any shocks on any axle. It all depends on the angle and installation as to whether they will function the way you want them to.
With the Losi's on the Bully axles make sure you have plenty of spacers handy and dont be afraid to run them wide at the chassis. The Losi's have a long stroke so the angle of the shock can change more as the as the suspension articulates. Make sure you can go through your entire range of motion on the axle without the shock binding on the gearbox. This can put pressure on the angle of the shaft in the body and cause leakage. This is true on any shock but ESPECIALLY the leakylosi's.
Culetto is offline   Reply With Quote
Old 06-28-2009, 04:54 PM   #4
with the Fubar chassis i had to change the shafts to shorter ones.unless you are running a very tall chassis i think you will have to do this or put limiters inside the shock on the shaft.
jamesdicken is offline   Reply With Quote
Old 06-29-2009, 10:05 AM   #5
I am also using losi shocks and they fit fine once you figure out your spacers. I had to use 3/4 inch limiters externally on the shafts to avoid 90 degree articulation.
69CrazyHorse is offline   Reply With Quote
