Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > RC4wd Bully
Thread: Bully or Berg?
Old 06-30-2009, 06:34 PM   #1
Default Bully or Berg?
Okay so I am going to take the leap into MOA. So I am going back and forth between these two axles. I am leaning more towards the bully just because of the price, but what I am wondering is what is the main difference between these two axles? Are parts too hard to get for the bully? Or am I even really going to need to get any extra parts with the new bully? Besides the axles what else should I plan on purchasing to make these axles "bulletproof"?
Thanks for any input guys. Would post this is the berg section too, but I know that most that would respond there are way to biased, where as a lot of you guys seem to have worked with both of these axles.
Drvnbeing is offline   Reply With Quote
Old 06-30-2009, 06:53 PM   #2
thats what makes the bullys the best. they are ready out of the box. bergs you should plan on buying at least 3 sets of axial stub axles, drilling the tubes for a servo mount, buying lockouts for the rear and rims that will only fit berg axles (the bullys use a more common axial offset, and drilling the gearboxes to clock the rear up off the ground. You also have to buy pinions for the bergs and they are metric only.
Culetto is offline   Reply With Quote
Old 06-30-2009, 06:55 PM   #3
derwood21's Avatar
I don't have any personal experience with the Bergs but I'm totally happy with my Bullys. I have only had them a couple weeks but they have been through a beating. The only thing I can think you need to get with them in a steering kit. So far it looks like no one else has had any probs with these out of the box strength wise since the v4 cvds are in them. I know many guys running bergs and have been through axles front and rear, lockers, and started running modded axial stub axles to strengthen them. Bullys are cheaper right off the bat and comp ready out of the box. The only thing I can think of as a downside to the Bullys is the are pretty heavy and some guys like to run light rigs.
Are you in Auburn CA? If your in the area, Swing by the Hobbytown in Folsom sometime. I always bring mine in to work if you want to check them out.
derwood21 is offline   Reply With Quote
Old 06-30-2009, 07:02 PM   #4
Right on thanks for the responses. And yeah I am in Auburn, Ca. I'll have to swing by some time I have yet to be to that location. Now I don't have any experience with either of these axles, but for those that do, how does the quality of work compare? Housing wise, do the screws seem to strip out easily or any other problems with either of them?
Old 06-30-2009, 07:11 PM   #5
I just bought a new set of Bully's and they are sweet thus far. I know allot of people who run Bergs and one of the more successful ones at comps told me to go with the bullys so I did and am very happy about it.
69CrazyHorse is offline   Reply With Quote
Old 06-30-2009, 07:15 PM   #6
yep.
i think the thing that i like is the normal width on the bullys. also the bullys are way beefier then the berg!
jamesdicken is offline   Reply With Quote
Old 07-01-2009, 01:44 AM   #7
I've only heard of one stripped screw and it was a manufacturing issue and RC4WD replaced the part. Thats probablely one of the best things about the bullies. You can talk to the manufacturer if you have an issue and they have great service. Good luck getting the same with the bergs.
Old 07-01-2009, 02:49 AM   #8
Well since this is the Bully Section I will say go with the Bully's
I went with the Bully's because of the narrower width and stuff like the high clearance knuckles, rear straight axles and beefier drivetrain.
I am not krazy with them but they have held up fine to what I have thrown at them so far.
And now with the Bully II's out and being cheaper it almost makes no sense to NOT go with Bully's!!!!!
Xtant3150c is offline   Reply With Quote
Old 07-01-2009, 02:59 AM   #9
Tried my very best...
Dr.Frank's Avatar
Hello,
i'm a "MOA sissy" too . For the price of one comp ready set of bergs you
can pick up two sets of bullys. I'm driving the bullys now for three weeks
and are very satisfied with them, means i can beat on them and they don't
cry a bit, straight out of the box.
Greetings from Germany
Frank
Dr.Frank is offline   Reply With Quote
Old 07-08-2009, 11:30 PM   #10
I like to #*&^
i havent work with either but id say if i had to pick to buy them id go bully
2500hdon37s is offline   Reply With Quote
Old 07-09-2009, 12:31 AM   #11
crash's Avatar
I am in the same boat--and I am pointing towrards the bullys
crash is online now   Reply With Quote
Old 07-09-2009, 08:13 AM   #12
I like to bully other rig so bully is my choice....
dr_rookie7 is offline   Reply With Quote
Old 07-09-2009, 08:47 AM   #13
Default Go Bully, better axle width
I have a Berg, and a local rc crawler has the Bully.
His only advantage is the axle width. HUGE ADVANTAGE come gate time.
my berg seems like 3/4" wider and I'm too into scalers to spend $100 on offset wheels..... I play with toy Trucks and cars just for fun
BULLY
Rocksolo is online now   Reply With Quote
Old 07-09-2009, 08:55 AM   #14
Just build two rig like me so there is no question. Either berg or bully shoot even a HR is going to be better to drive than any shafty
Flyin Hawaiian is offline   Reply With Quote
Old 07-09-2009, 09:57 AM   #15
crash's Avatar
I have looked thru the specs on the RC4wd site and they don't state what pinions comes with the axle. Can anybody shed any light on this?
Old 07-09-2009, 10:07 AM   #16
Stock bully pinions are 12t
Bully axles are for sure the most comp ready axle on the market right outta the box...you cant go wrong IMHO.
53 willys is online now   Reply With Quote
Old 07-09-2009, 10:11 AM   #17
crash's Avatar
Thank you
They only state "pinion included" on the site with no reference to the tooth count.
I am sold and will be going with the bully's. My only concern is what I hear about the slop in the knuckles..
Old 07-09-2009, 10:17 AM   #18
Thank you
long as you keep the knuckle bolts loc tighten in then the small amount of slop should not be an issue...
Old 07-10-2009, 01:40 PM   #19
I have been going back and fourth between buying a Bully Crawler or a Newage Berg. The only thing that bothers me with the Bully is the 4-8 days just for order processing from rc4wd. If i do break something I haven't already purchased I for sure don't want to wait 4-8 days for the order of replacement parts to get processed much less shipped and then transit time in shipping. When I order hobby items online most places I order from ship within 48 hours the majority process an order and ship it out the same or following day. I am going to order one or the other by Monday still haven't decided which one yet.
Whats everyones experience with ordering both bully and berg items ?
M_Saint is offline   Reply With Quote
Old 07-10-2009, 03:41 PM   #20
if your worried order spare parts before they break.... RC4WD has always shipped my spare parts really fast.
