| | #1 |
| Looking for scale goodies ![]() Join Date: Dec 2006 Location: In Cali.
| Hello guys and gals, I have been wanting to get this thing done for a while now. Just couldn't find the time. So since I am going to BFGTG2 this weekend I figured I better get started. Better earlier than at 3 in the morning the day of the comp. Since I have a 3 hr drive to get there, that would probably not end good. So I got the ARTR truck kit. Came all boxed up really nice. Prebuilt. Mine needed tweeked, but thanks to Rob the new Bully ARTR kits will be ready with proper link and shock placement for a great start up. I was the Rock Rider and Copperhead man. I chose to work with these items for my build up. Mamba Max ESC Hitec 5955 servo Dual dig switch setup (2) 35 turn motors (if I can find some) Low Boyz wheels 3 cell lipo OG bug body I chose to give the stock links a try. So I moved them around a little and adjusted the shocks a little and I feel like I have a decent setup to get started with this truck. I have another Bully, but its the OG machined cases, so they will get a rebuild with another chassis soon. Just need to find one. I, of course took the axles apart and threadlocked all the screws. Used red on the knuckle screws. May need to do this a few more times to insure a solid lock. So here is my new baby. lol ![]() I may have pushed the limits of the rules for bodies. If not, then I will cut a little more off. ![]() ![]() These wheels are perfect fit for the bullies. The extra weight in the axles really make no need for too much weight in the wheels. ![]() Not sure if this will be the end all steering setups, but its my shot at it. ![]() Trusty dual dig switch setup. The plate in the chassis is real nice. ![]() Nice little spot to install my switch too. ![]() So now I need a little paint and a plate for the rear axle for my Lipo. Be back soon. |
| Sponsored Links | |
| | #2 |
| It has way to much clearance for me, but I wanted to stick with the stock links. This may require some work down the road. |
| | #3 |
| RCC Addict ![]() Join Date: Sep 2007 Location: Grand Forks
| Looks good I think the body could use a bit more trimming Last edited by 701 Technique; 08-04-2009 at 12:07 AM. |
| | #4 |
| RC4WD Team Mgr/W.Pa.C. ![]() Join Date: Nov 2005 Location: Here
| | #5 | |
Good eye. I have to tighten the lower links. They keep folding over to the side. I agree on the trimming. Time to get out the ruler again. John....a half/half may end up where I go next. Not sure though till I run her. | |
| | #6 |
| I ran this on the rocks this weekend at BFGTG2. The truck did great. Especially since the first scratches were earned on the first course. I am really happy with the set-up. I did change things from the stock setup. However, these changes will be on the new Bully kits. The X-locks had no real issue. The foam setup is center half is memory foam. (Red Kreepy) and then I put 1/4 sections of the stock foam on each side. I do need to do something with my shocks. Not sure what I will do, but it was a little bouncy. |
| | #7 |
| Are you using the stock shocks??? I had that same problem. I ended up getting rid of the springs and going full droop. Only problem is at full compression they sometimes stick...I will be adding fuel tubing to limit the compression... |
| | #8 |
| Pebble Pounder ![]() Join Date: Feb 2009 Location: Highlands Ranch, CO
| Build looks great Racer. I can't wait to see some updates. Your rear axle looks like you clocked it a bit with longer uppers. Do you have any issues with the gearbox hitting the links when articulating? Mine is clocked a little less and it just about touches when completely flexed. Also, any issues with the axle hitting rocks when climbing with the bent links? This was a constant problem for me until I switched to straight links. |
| | #9 |
| Motorama Bound ![]() Join Date: Oct 2005 Location: W.Pa.C.
| Looks good. I'd also suggest either a shorter shock or going to droop like John did. How's that servo arm holding up for you? I bent 2 of them badly before I went away from the inverted servo horn. |
| | #10 | |||
Not sure where I am going with it next. Quote:
I really didn't notice the axle hitting much. I know my motors took a beating. I am pretty happy with the bent links so far. However, I am not done tweeking it. Quote:
Rather than switch the setup, I may have a bar made to protect it. | |||
| | #11 |
| ......../-__-\........ ![]() Join Date: Nov 2007 Location: Memphis
| So do your shocks not stick? I never thought that I would see these on a comp rig due to their sticking problems. |
| | #12 | |
I did mean motor and not axle. I noticed that it would knock my gear out of mesh frequently. | |
| | #13 | ||
I didn't take any real hard hits at the motor. They are scratched. So I am not aware of any issue with the motor moving. Might want to use a lock washer on the bolts? | ||
| | #14 |
| Okay, so I up and mounted some of the RC4WD 110mm Sparks Comp Shocks. These helped lower the chassis down to a decent height. Probably around 2.75 now. They seem to be a little better and I only need to remove the clear dust covers for them to work okay. May need to grind the one corner of the gear case, but we will wait and see. Everyone loved my ugly duckling body. I'll post up some shots when I get the camera back. |
| | #15 |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
| | #16 |
| | #17 |
| | #18 |
| that thing looks cool |
| Thread Tools | |
| Display Modes | |
