| | #1 |
| Paradox Team Leader ![]() Join Date: Jan 2006 Location: The PARADOX NATION
| Hi everyone, Well I jumped on the M.O.A. bandwagon as of last night. I ordered a set of Bully 2's. It says my order is still pending. Hopefully that's a good thing. I have a new chassis in the works too. I can't wait to get my axles and get started on a new build. Last edited by rmdesignworks; 12-26-2009 at 02:24 PM. |
| Sponsored Links | |
| | #2 |
| Looking for scale goodies ![]() Join Date: Dec 2006 Location: In Cali.
| Good luck with your build. Be careful with discussing your website and making a chassis all in one post. |
| | #3 |
| RCC Addict Join Date: Aug 2005 Location: VARCOR
| Chit Chat |
| | #4 |
| previous post edited my point in my previous post was that i am working on a new chassis for my axles,,,all new skid design,,, new 3-link design,,well actually not new just built a little different,,,,new side plates,,, and my own servo mount i'm also workin on a relay setup to fight the clod stall effect,,,and incorporate a dig set up some how...my main concern is the clod stall though later guys,,,sorry for the confusion in the first post Last edited by rmdesignworks; 08-05-2009 at 12:35 AM. |
| | #5 |
| Rock Crawler Join Date: Mar 2008 Location: lodi
| clod stalls awsome! dont get rid of it lol. |
| | #6 |
| Pebble Pounder Join Date: Nov 2008 Location: roseville
| i too just took the plunge as u send, and was also concerned with getting my axles. it took a while too get a response back from rc4wd. but it only took 8 or 9 days from ordering to them arriving on my front door. i used the cheapest delivery option too. which seems to be par for the course, at least in expeirence. |
| | #7 |
| i sent RC4WD an email to see wha tthe "pending" on my account meant,,heard back from Mike @ RC4WD and he said it should ship early to mid next week....hopin for early |
| | #8 |
| This is what I am thinking about the relay system to eliminate the stall effect. |
| | #9 |
| Quarry Creeper Join Date: Sep 2008 Location: tucson
| Hope the relays work. Also waiting for my axles hope fully they ship next week ready to get back to crawling |
| | #10 |
| workin on the new chassis,,and i have started a newer design similar to a "stick"......according to rc4wd the axles shipped today....i also ordered 2 new integy 55t lathe motors....closer closer closer |
| | #11 |
| My Bully's and 55T's arrived today,,,,design,design,design |
| | #12 |
| Pebble Pounder Join Date: Nov 2006 Location: vaca, nor cal
| Hopefully the lower "3-link" works out alright. I think it might hinder articulation more than the AX-10's uppers. |
| | #13 |
| Well all of my research says it will work,,and the major hope is that it will solve the clearance issue of linkages around the gear case and motors. My mock up didn't show any problems but we will see for absolute sure when the parts get done at the cnc machine. My 3 link on my custom shafty works really well,,standard set up and ofcourse reversed from the "Razor". |
| | #14 |
| Hateraide ![]() Join Date: Dec 2008 Location: Mission BC
| the have done 3 link designs like that in the real world it will work fine i like the design |
| | #15 |
| Code454,,Thanks,,,I did see a couple of designs on real trucks that were similar but they had a welded tube set up,,looked like links triangulated and welded together where they met under the vehicles' chassis,,they also used a pivoting tube instead of a ball end where the member met the chassis,,I'm hoping it will also help with the inevitable problem with the chassis edges hanging up on the rocks as it passes over them....The upper links will need to be really short due to the overall length of the lower link,,,I'm planning on covering the chassis and lower links with Teflon or Tyvek. The difference with using the fixed one piece lower link too it that it should help with "swing steer" because of the axle actually pivoting at the center point of the chassis instead of pivoting at the upper links,,,again this is something we will have to see for absolute sure when the parts get done and built together. Last edited by rmdesignworks; 08-16-2009 at 12:08 AM. |
| | #16 |
| I sent the C.A.D. over to the machinist and he says all is good and thinks everything should be ready by or before next weekend. I was having concerns about mounting the shocks. I don't want them rubbing the tires or cases/motors. I think i'll use 8mm collars on the linkage arms. I will probably have to drill and tap a second hole in each one to bolt on the shocks, and use the original set screw hole to secure the collar to the arm/s. That way too I can adjust the shocks forward and backward on the arm to set up the suspension the way I want it. One thing though,,,,,droop or sprung? I know quite a few Bully rigs are set up both ways,,Input guys? |
| | #17 | |
| Motorama Bound ![]() Join Date: Oct 2005 Location: W.Pa.C.
| | #18 |
| I'm actually running full droop on my tlt axled crawler and I do like it and I am leaning toward full droop on the Ockham's Razor chassis with the Paradox links,,but I'm not fully decided yet |
| | #19 |
| Rock Crawler Join Date: Aug 2008 Location: Tucson
| I like it a lot, subscribed. Keep us posted. |
| | #20 |
| Ive started workin on a body too while I'm waitin on the CNC machine,,, Real close to a Bronco,,a little different hood and cab and front and rear narrowed,,,about 4" wide at the cab and down to 2.75" at the grill and tailgate,,about 3.75" high trimmed and about 11.50" long.. I've drawn up two versions,,HALFCAB and HARDBODY |
| Thread Tools | |
| Display Modes | |
