Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > RC4wd Bully
Thread: MFM Black Widow?
Old 08-11-2009, 03:20 PM   #1
Rockin' with SMRCRC
papabash's Avatar
Default MFM Black Widow?
Hey guys,
Tired of popping driveshafts and tranny gears, etc., so I think it may be time to go MOA. Definitely will be the Bully2's, but I need to be budget friendly. I have an extra Black Widow chassis sitting around (LOVE the one on my current ax10 comp rig), and was wondering if there is any reason why I couldn't use it to build a Bully rig. I did a search, but couldn't find where anyone has done this before. I know I will probably have to fabricate all the links, but that's no biggie. What's the consensus from you guys, try it, or forget it? Thanks!
papabash is offline   Reply With Quote
Old 08-11-2009, 03:29 PM   #2
what i did when building my bully was also look in the berg section tyo see what they were running. i went with a totally new chassis with vanquish and h\am having good results. most guys are running the lighest chassis possible since the bullys do weigh more then the bergs but in all reality the setups are simular. same electronics same chasis same tires different offset of rims. do your reasearch in both sections you should easly find someone running a blackwidow berg. i dont see why it wouldnt work the only problem i see is the bottom skid is longer then most moa chassis and you might have motor and axle houseing issues with it depending on how you set everything up. you allready have one laying around try it and if it doesnt work try one of the inexpenisve proven chassis out there like the skeeter or cdws new chassis. its all about trial and error and what will work the best with your driving style.
punkuup5150 is online now   Reply With Quote
Old 08-11-2009, 05:20 PM   #3
Picky Fab'r/Acetal Junky
Offroader5's Avatar
I don't see why it wouldn't work. Give it a try
Offroader5 is offline   Reply With Quote
Old 08-11-2009, 05:41 PM   #4
Black Label Crawlers
Jeepial's Avatar
I say roll with it..Cheaper to use what you have for sure..
Jeepial is online now   Reply With Quote
Old 08-11-2009, 08:04 PM   #5
x2,then post up some pics!
jamesdicken is offline   Reply With Quote
Old 08-11-2009, 09:49 PM   #6
I say give it a try to.
I would be interested to see how it works as I have a Black Widow chassis
Xtant3150c is offline   Reply With Quote
Old 08-11-2009, 10:15 PM   #7
I have a black widow berg and like it so far....definitely cost effective, especially if you have one sitting around like I did.
born-again widow
bent70 is offline   Reply With Quote
Old 08-12-2009, 09:31 AM   #8
long as the lower links are on the VERY end of the chassis/skid you should be fine....and it looks like they are on the BW..
post up some pics when you get the build going
53 willys is offline   Reply With Quote
Old 08-12-2009, 10:34 PM   #9
I had a black widow on my berg axles and loved it. Won some comps with it also.
ubbb69 is offline   Reply With Quote
Old 08-13-2009, 07:24 AM   #10
Rockin' with SMRCRC
papabash's Avatar
Okay, I think you guys have convinced me. I can save enough $ by using my BW to buy my motors and esc, so I think I'll go for it. I'll try to get some pics up for you as I build. Thanks!
Old 08-13-2009, 10:37 PM   #11
Kewl!
Looking forward to the build.
Old 08-16-2009, 08:13 PM   #12
I would like to see a Black Widow Bully. My buddy runs the black widow on his berg and it works great.
69CrazyHorse is offline   Reply With Quote
