| | #1 |
| Paradox Team Leader ![]() Join Date: Jan 2006 Location: The PARADOX NATION
| I'm looking at the axles I just received,,I love these monsters,,,it looks like the gear covers may cause some clearance issues. Is anyone not using the gear covers,,taping the case or ? |
| Sponsored Links | |
| | #2 |
| support@rc4wd.com ![]() Join Date: Nov 2007 Location: Lancaster, Ohio
| They may cause clearance issues for some. I have never ran them just to see how much junk i could get in the gearbox before I had issues but, I haven't had a problem yet. If you want to cover them and they do become an issue with clearance i suggest using it as a pattern and cutting a piece of lexan the same shape |
| | #3 |
| Ok,,,thanks,,I wa thinkin about some black electrical tape,,or a piece of lexan with small button head screws,,so the covers are coming off,for sure.... |
| | #4 |
| ... Join Date: Sep 2005 Location: USA
| I just use 2in Wide Clear packing Tape... I have from day one... |
| | #5 |
| RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
| I made a lexan one as well. I only had to space out one of the screws as it was hitting the gear inside. |
| | #6 |
| Rock Crawler Join Date: Mar 2008 Location: lodi
| i use lexan from the body i got when i first set up my bullys but ive also seen stickers or decals from hobbyshops/crawler part manufactures |
| | #7 |
| Rock Crawler Join Date: Feb 2008 Location: Golden Corral getting Fat
| I am Runnimg them on a Jp Havoc ARTR and there are no issues |
| | #8 |
| RCC Addict Join Date: Jul 2008 Location: Sin City
| Originally i ran duct tape but they do fit with my Havok build. The bigger issue with them is the motor slipping and changing your pinion mesh. Happens alot. |
| | #9 |
| I wanna be Dave Join Date: Jan 2009 Location: 801-Utah
| black duct tape here..... |
| | #10 |
| I'm Dracula, Bitch. ![]() Join Date: Sep 2005 Location: Houston, TX
| The lack of shocks reduces many of the clearance necessities.... The front shocks interfere slightly...not really a big deal, but the lexan idea is a good one. I might make up a new cover this weekend. |
| | #11 | |
| Shut up Dave ![]() Join Date: Dec 2005 Location: Romeotucky
I have had that same problem.... not sure what a fix would be. I am using a piece of AE chassis protector. Its about impossible to get off so you dont have to worry about the lubricating grease bothering it. | |
| | #12 | |
| I wanna be Dave ![]() Join Date: Dec 2005 Location: Gold Bar
As for the pinions loosening up. I only have that issue when I am WOT around in my shop.... | |
| | #13 |
| I have never had my motor mounting slip.....I like to use a really small bit of blue loc-tight on my motor bolts...just dont use to much you dont want it to get inside the motor. |
| | #14 |
| I actually havent either since I filed the tip on the set screw flat. Had the same issue with my MIP shafts on my tlt shafty. You grind the set screw to get more surface area against what its pressing against and that seems to resolve the issue--at least for me it has... |
| | #15 |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
| I used a flat piece of lexan from the bottom of a body mold. The lower links on my Havok build had to be bent pretty good to get around the cover and caused a lessened steering angle due to the tires rubbing the links. Once I put the thinner lexan in place, I could take alot of the bend out of the lower links and get a bit of my steering back. |
| | #16 |
| Rock Stacker Join Date: Oct 2008 Location: Ottawa Canada
| I'm running mine uncovered but drilled extra clocking holes to get them up high. |
| | #17 |
| is anyone running a three link? does anyone have good clear close up pics of the axle mount of a "stick" chassis? I know some are using a ball link from mcmaster but it isnt real clear how it's mounted crawlmater,,,do you have pics? |
| | #18 |
| nevermind about the "stick" mounting pics,,i completely forgot about the closeups on rc4wd.com's website on the Bully page. but how about the 3 link? |
| | #19 |
| Quarry Creeper Join Date: Dec 2008 Location: Aurora Colorado
| I cut mine out of sheet metal. But I think lexan is the way to go. All you do is trace them with an Xacto knife on lexan. |
| | #20 |
| Thread Tools | |
| Display Modes | |
