| | #1 |
| Quarry Creeper Join Date: Dec 2007 Location: U S A
| Not much of a build thread but here's my Bully. T1E Rockshow 104mm Zero shocks droop w/ TCS medium springs, 3/4" limiters RC4WD Bully axles Mayhem 7s Chisel G8s stock memfoam w/ 1/4" hard foam slices in and out Novak55s (subject to change) Traxxas upper links, Berg rear lowers, Axial bent front lowers Hitec645 (waiting for Santa to bring me a better one) RC4WD modified steering kit Took the axles apart and locktited everything and lubed the gears. Going to start on the electronics once everything gets here. Made the body panels from a scx10 stock body ( the roof is from the roof, the hood is from the hood, the sides are from the bed) I like how its turning out but the test will be the rocks so we will see Thanks for looking ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| Sponsored Links | |
| | #2 |
| Black Label Crawlers ![]() Join Date: Sep 2008 Location: behind the wheel of a monster truck...
| Awesome Bully..I like how your body looks,bit different from the normal Rockshow.Love those Mayhem wheels too.. |
| | #3 |
| Rock Crawler Join Date: Dec 2007 Location: GILBERT
| that thing looks great! good job |
| | #4 |
| Looking for scale goodies ![]() Join Date: Dec 2006 Location: In Cali.
| Nice work. Really like the body work! |
| | #5 |
| Thanks guys! I hope to get it a runner today getting tired of pushing it around and making vroom vroom sounds |
| | #6 |
| I wanna be Dave ![]() Join Date: Dec 2005 Location: Gold Bar
| I like it |
| | #7 |
| Thanks! Started to make a dig unit for it but scrapped the idea and went ahead and ordered a PunkRC dig so looks like testing this weekend is out On a side note the Kamikaze dig plate fits this chassis perfectly, bolt holes lined up and nestled exactly one bolt hole to either side of the cab standoffs...coincidence? You be the judge ![]() Got the Rooster Crawler mounted down in the belly (I know it's old school, but I never had had a problem with them other than the cell restriction). Mounted Kamikaze's dig plate and the rx, patiently awaiting the PunkRC dig and I'll be under way! I made a battery plate from an old Axial tray, I may change this later its a little high but room is limited. A few pics of where it sits now. ![]() ![]() ![]() |
| | #8 |
| You will love the punk dig switch |
| | #9 |
| RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| Great looking chassis! |
| | #10 |
| Rock Crawler Join Date: Dec 2007 Location: T1E Country
| That turned out very nice. The body panels look great !!!! |
| | #11 |
| In between. ![]() Join Date: Jul 2006 Location: Moscow Mills MO
| truly clean. I like it. Please let us know how the suspension setup works out |
| | #12 |
| | #13 |
| Punk R/C came through with the dig switch and this product is just sick, I highly reccommend it to anyone running MOA needing a dependable, small, plug and play dig. So as soon as I finish soldering it starts to thunder, figures. Anyway, here's my Rockbully ready for rocks next to my 2.2 scale for size comparison. You can also see the flex from the new internal springs, that's max flex before the rear tire starts to lift, I'm sure it will break in a bit over time, but so far I'm pleased. Thanks for looking ![]() ![]() |
| Thread Tools | |
| Display Modes | |
