Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > RC4wd Bully
Thread: wheel weight's on the bully's
Old 08-19-2009, 12:09 PM   #1
Default wheel weight's on the bully's
I was wondring if any one was running any weight in the wheels on the bully 2's. If so how much.
jmontes_21 is offline   Reply With Quote
Old 08-19-2009, 12:15 PM   #2
I'm Dracula, Bitch.
JeremyH's Avatar
Why would you need to? The axles already weigh a ton....
JeremyH is online now   Reply With Quote
Old 08-19-2009, 12:17 PM   #3
crash's Avatar
Look at my build thread for some ideas
crash is online now   Reply With Quote
Old 08-19-2009, 01:49 PM   #4
Scorched Earth MF'r
Boogie's Avatar
You need wheel weights for a bully?
Seriously though, I've thought about running some RC4WD Lowboyz active wheel weights, but wouldn't be running enough weight in them really to justify getting rid of my mayhems and spending $150 on a new set of wheels.
Boogie is offline   Reply With Quote
Old 08-19-2009, 01:49 PM   #5
i think dads truck has 4oz in each front
jamesdicken is offline   Reply With Quote
Old 08-19-2009, 02:18 PM   #6
we run a total wheel weight of 15ounces with a dna wheel in front per side
none in rear
twistedone is online now   Reply With Quote
Old 08-19-2009, 02:28 PM   #7
MF&W
moes670's Avatar
13oz total per side in the front. Thats wheel,foam,tire and stick on wieghts. No weight added in the rear.
moes670 is offline   Reply With Quote
Old 08-19-2009, 08:44 PM   #8
3.3 in each Front DH Procomp and none in the rear.
69CrazyHorse is offline   Reply With Quote
Old 08-20-2009, 02:06 PM   #9
I run some in the front, one strip of 1/4 oz. weights on each front just to help with breakovers
nismotuningrocks is offline   Reply With Quote
Old 08-21-2009, 07:01 AM   #10
Need Tough Links?? PM Me
xirtic's Avatar
x2
xirtic is offline   Reply With Quote
Old 08-21-2009, 08:43 AM   #11
Shut up Dave
jetboat's Avatar
Im running Bully v1's with SPI rocker wheels with double weights up front and singles in the rear (not sure what that amounts to). Its allot heavier rig than I am used to running but really keeps you planted and the rockers are great at keeping the weight as low as you can get it.
jetboat is offline   Reply With Quote
Old 08-21-2009, 09:50 AM   #12
Thanks guys i have a good idea of what to do.
Old 07-26-2010, 02:58 PM   #13
I'm running Bully with RC4WD Lowboyz and put additional weight for the front wheels (each set weight 385 grams (13.5 oz) incl. tyre). But for the rear wheels no additional weight at all even I've took off the original pendulum weight.
STRESS_AIR is offline   Reply With Quote
