Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > RC4wd Bully
Thread: Bully axle/SWX?
Old 08-19-2009, 11:57 PM   #1
xgerstandtx's Avatar
Default Bully axle/SWX?
hey guys, jumping into the MOA market soon, trying to decide what route to go. i have my axial/swx chassis and just love it. Trying to figure out if i would be able to use it with bully axles? i know the skid is a little long and the links would be short but do you think the added width of the chassis would help negotiating the links around gear boxes and motor.
Or option 2 is to pony up the moneys and get the kit version with alum wheels and chassis ready to go just tune it. trying to figure best option.
xgerstandtx is online now   Reply With Quote
Old 08-20-2009, 01:22 AM   #2
it will work
ronbeck is offline   Reply With Quote
Old 08-20-2009, 05:27 AM   #3
You can get the Kit version of the bullys but there are so many options out there for a chassis that are very affordable. Personally i like the HavoC on my bullys. The weight of the axles and the lightweight delrin chassis keep the cog very low and the torsion on the front end will let you pull up over alot of breakovers that a normal sprung rig might have to overthrottle to get up.
Check it out HERE.
(Yes im sponsored by JPCustomRCs.com but i was running the HavoC before I joined the JP Team so its not a biased opinion)
Culetto is offline   Reply With Quote
Old 08-20-2009, 02:04 PM   #4
I think I may have glanced at something that said the swx's lowers are too narrow to clear the bully cases, but I may be wrong
nismotuningrocks is offline   Reply With Quote
Old 08-20-2009, 02:32 PM   #5
MF&W
moes670's Avatar
I would stay away from the kit version from RC4WD. Unless you are just looking to get up and running right away. Can't speak for the other kits. I bought the RC4WD kit which works fine for the kid to run in the novice class. The shocks are pretty weak and there are better tires for the rock we have around here. That and the chassis is pretty soft aluminum bends too easy. But it was ARTR so it wasn't overwelming for the kid to get it running than say building something from the axles up.
Stick with the chassis you have if you like it. You probably we need double bent links like Crash did on his.
moes670 is offline   Reply With Quote
Old 08-20-2009, 02:57 PM   #6
Buy the axles and try it, if it doesn't work you can pick up a good chassis for $50-$110
paintballer9876 is offline   Reply With Quote
Old 08-20-2009, 03:08 PM   #7
That was probably in the thread I created. The skid is to long making the links to short. The rod ends hit and bind on chassis. I tried on monday and it didt work no matter what I did. You can always try yourself but most likely wont happen. I had planned to get the jp hellstrom but got offered a vanquish for cheap so Im going that route.
axman2010 is offline   Reply With Quote
Old 08-20-2009, 11:41 PM   #8
i think i saw that post alson on how you had a hell of a time with those link lengths. probably should just save a few more pennys and poney up to the jp customs build. thanks for the input and i just need to decide between a four letter word (losi) or the bully set. thanks guys i believethe swx is gonna be scratched off the list with bullys
Old 08-20-2009, 11:58 PM   #9
hey the swx will work for a bully. i just put one together yesterday. its very close but does work. you will love it. i have now build a swx berg and a swx bully and they dominate. i will get some pics of the swx bully up and show you. now its just time to compare both swx rigs together.
webster420 is offline   Reply With Quote
Old 08-21-2009, 12:35 AM   #10
yes please post up pictures with some specs on what you used. thanks for making my decision harder.
Old 08-22-2009, 12:22 AM   #11
i will post some pics asap. i havent had time to take any pics of it yet. its my buddies truck and we have been trying to get it built and fined tuned so he can learn to drive it for a comp. here is some of the specs we used.
bully axles.
swx chassis
hitec servo
bully steering kit
tekin fxr
2 45t tekin motors
punk rc dig
losi shocks
spektrum dx3r
cc bec
axial wheels
hb rovers
and a ton of weight.
