11-16-2009, 08:59 AM | #1 |
Pebble Pounder Join Date: May 2006 Location: St. Louis
| What Happened?
So yesterday at the comp my rig died on the finals course. I just figured it was the battery hitting the lipo cutoff. I went to charge said battery and its still at 11v. I did notice something strange. With the battery out of the rig, I spin either the front or rear tires and the other tires spin too like if it was a shafty. It shouldn't do this. I can't get the crawler to move under its own power with the battery. Did something get fried?
11-16-2009, 09:25 AM | #2 | |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
11-16-2009, 09:31 AM | #3 |
Thanks for the info. This is my first MOA rig so I just never noticed this before.
11-16-2009, 09:57 AM | #4 |
how old are the motors? check brushes, maybe the hung up or need replacing? different pack do the same thing?
11-16-2009, 10:00 AM | #5 |
Motors are newer. Probably had 4 or 5 batteries through them. I'll take a look at them just to make sure they're good.
11-16-2009, 12:28 PM | #6 |
Rock Crawler Join Date: Mar 2008 Location: lodi
check gear mesh also. with motors getting smashed up on rocks the mesh can get very very tight doesnt happen often that it stalls out the motors but could be one of the causes. also as stated above check brushes i knwo my integys are about 3 months old and the brushes are allready chipped big time so im haveing alot of power loss from this also
11-16-2009, 12:34 PM | #7 |
Found the problem. Guess my soldering wasn't good enough as I broke a joint between a deans end and a wire from the ESC. Thanks for the ideas and I'll take a look at the mesh. I'm getting ready to swap out the 55's for 45's.
