Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Bully 2.2 Black Delrin Inverted Servo Mount
Old 01-12-2010, 01:59 PM   #61
I dont even want to think about how hard you would have to land on this thing to break it. Its beef!
Culetto is offline   Reply With Quote
Old 07-02-2010, 11:38 PM   #62
Does he still makes these?
hairumuffin is offline   Reply With Quote
Old 07-03-2010, 06:57 AM   #63
Yes....I still produce these mounts. I am currently out of stock and awaiting a shipment from my machinist. I keep stock-status and estimated re-stock times on the first post of this thread. Please check back in about a week. Thanks.
xirtic is offline   Reply With Quote
Old 05-22-2017, 02:59 PM   #64
Default Re: Bully 2.2 Black Delrin Inverted Servo Mount
I know this thread has been dead for a while, but I just found my old Bully axles and found that I have two front axles but only one servo mount. Do you still make these servo mounts?
If not, does anyone make servo mounts for the Bully axles?
Thanks,
Deven
dleigh007 is offline   Reply With Quote
Old 05-22-2017, 04:40 PM   #65
Default Bully 2.2 Black Delrin Inverted Servo Mount
Dravtech
Find them at Dlux
https://dluxfab.ecwid.com/#!/Bully/c...0&sort=nameAsc
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 05-22-2017, 05:39 PM   #66
Those are for bully 2 not sure it fits original bully
Evo93 is offline   Reply With Quote
Old 05-22-2017, 05:45 PM   #67
Nor I, but it's a start
Hang up and Drive
Old 05-22-2017, 11:31 PM   #68
What are the dimensions of the servo plate? Does anyone know?
https://dluxfab.ecwid.com/#!/Servo-m...egory=11553002
Does it fit the Bully 2.2 front axle?
Old 05-22-2017, 11:33 PM   #69
Or can someone that has the Bully 2 axles measure the distance between the servo mounting holes for me?
Thanks
Old 05-23-2017, 04:46 AM   #70
Thanks
I'm not next to my rig. But I believe the holes are the same width as a servos mounting holes. Just slightly offset from the holes that hold the servo to get it closer to the gear case. Might have to flip it as the gear case is on the opposite side on the original axles. If the offset doesn't work the original bully 2 mount is straight and you can get it from rc4wd.
Old 05-23-2017, 08:22 AM   #71
Thanks,
Deven
Unfortunately I no longer am in the production side of the hobby. I do not have any remaining stock, nor can I produce any more at a fair cost as I sold off my CNC Mill as I was not using it anymore.
Josh
Old 05-26-2017, 08:04 PM   #72
hay josh are you still making these if so can you send me a pic I don't have access to the vendor section here yet
barberton crawler is offline   Reply With Quote
Old 05-27-2017, 03:44 AM   #73
Look at the above post..
