01-19-2010, 07:58 AM | #1 |
Pebble Pounder Join Date: Feb 2009 Location: Highlands Ranch, CO
| VP Wheel Offsets for Bullys
I know this has been discussed before, but I couldn't find the exact answer I was looking for. I'm looking at getting some VP DH's for the front and 1.00 SLW's for the rear. Right now I have the stock RC4WD wheels on my Bully, which I believe are 1.5" wide. I'd like to get the front a little wider than it currently is, and keep the back about the same, hopefully finding a good balance between side hill ability and getting through gates. So, with that, can anyone offer suggestions on the hub offsets to use for the DH's in front and SLW's in rear? Thanks, EXW |
01-19-2010, 10:27 AM | #2 |
Quarry Creeper Join Date: Oct 2005 Location: Chattanooga
I have 1.0 SLW's with 600s on all 4 corners and they are a little narrow in the front but the rear seems to be about perfect. Rear track width with Rovers is about 10inches with the 600s. I have some 725s coming for the front. I am not sure about what offset for your DH's though. Hope that helps -Lex |
01-19-2010, 11:24 AM | #3 | |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
01-19-2010, 12:21 PM | #4 | |
Lextronix - That helps a lot. I'm running Rovers too and 10" for the rear width is what I'm looking for. Quote:
So, probably 600's for the rear, now onto the front: I want to go with the DH's in front for the easy weight changes. I believe the Bullys are the same width as Axial axles. I got this from VP's site: DH Offset / Axial Track Width 335 / 9.25 460 / 9.50 585 / 9.75 Also, they list the SLW with 600 Offset as 9.05 track width. So, if that equals out 10" with Rovers from the above post, then: 335 = 10.20" 460 = 10.45" 585 = 10.70" Does that make sense? I'm probably missing something, but can anyone with DH's on a Bully comment and also give a suggestion on a good width to run? Thanks, EXW | |
01-19-2010, 12:39 PM | #5 |
Quarry Creeper Join Date: Mar 2009 Location: fair oaks ca
i run slw 1in with 600 hubs i was 10.25 out side tire to out side tire, now with 725 hubs i'm 10.5 out side tire
01-19-2010, 01:35 PM | #6 |
Pebble Pounder Join Date: Jul 2009 Location: Woodburn
01-19-2010, 04:04 PM | #7 |
Rock Stacker Join Date: Mar 2009 Location: Jasper
I'm running Procomps up front with 585 offsets and 1" SLW 600's in the rear. Track width is 10.25" and 10" respectively with RC4WD X-Locks. |
01-19-2010, 05:42 PM | #8 |
Thanks, that is what I'm looking for.
