04-24-2010, 11:50 PM | #1 |
Quarry Creeper Join Date: Jul 2009 Location: Missoula
| New Beetlejuice Build
Specs: Beetlejuice Chassis V1 Losi 4" Shocks w/white springs Havoc front links T1ERC High Clearance Rear Links Dual FXR's Tekin 55t's CC BEC Hitec 7950 Vanquish SLW .7's Proline 2 Stage Foam White Rovers First off after receiving this chassis through trade here. I realized either the previous owner modded it or the original Beetlejuice was not in current spec at 3" wide. It was at 2.5". So not having any delrin, and not wanting to spend the money on some. I went and picked up some 1/4 nylon spacers at a local hardware store. I placed one at each end of each cross brace and was now within specs. Second the skid that was sent with it was too narrow for the V1 it was the V2 or V3 1 3/4 skid. The side plates appeared to have been heated and attempted to be bent in, but not completely like the newer chassis are. So I didn't want to heat it up and bend them in further for fear it would break or take too much of my height away and not be in spec. Didn't want to squeeze it around the small skid so I used my 2" havoc skid and it worked perfectly. Lastly I drilled some new holes in the side plates for the rear of the skid to sit higher and at an angle. Then dremeled off about 1/4" from the rear angling down to the front. Sizes: Width at top of chassis 3" Width at skid 2 3/8" Wheelbase 12 3/16" Wheelbase compressed 12 3/8" Front TW 10.5" Rear TW 10.25" GC Front skid 3 1/8" GC Rear skid 3 3/8" On to the pics. |
04-24-2010, 11:56 PM | #2 |
| more pics
More pics
04-25-2010, 07:49 AM | #3 |
Quarry Creeper Join Date: Jul 2009 Location: St. Charles
that looks sweet man, i like the rims and the dew skins are cool too. nice job.
04-25-2010, 09:49 AM | #4 |
Rock Crawler Join Date: Dec 2007 Location: T1E Country
I like the green Dew panels too. Nice build. Any way you can mount the battery off the upper links and a little more forward? |
04-25-2010, 11:57 AM | #5 | |
Thanks, Yeah I need to find a better spot for the battery. I can slide it further forward, just need to make sure it doesn't hit the shocks. Maybe come up with something else have to play with it a bit. | |
04-26-2010, 01:46 PM | #6 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
Looks nice, I'm glad you decided to keep the bully thing going. |
04-26-2010, 05:01 PM | #7 | |
How do you like the .7 SLW's?? | |
04-26-2010, 07:06 PM | #8 |
I havn't ran the whole rig much, but testing around the apartment I like em. Full stock steering epa's set to the max no rubbing on links or shocks. Only down side is getting the weight up front I would like. Both axles are the lightweight versions. The batteries are a bit big, might pick up some smaller ones. Those fit perfect in the skid of my Havoc with some hanging off the front end, but not so great on this one.
04-27-2010, 09:33 AM | #9 |
Quarry Creeper Join Date: Apr 2010 Location: Hells Hole
are the dew skins a sticker or did you cut up some cans drill and mount them.
04-27-2010, 04:44 PM | #10 |
04-27-2010, 04:52 PM | #11 |
thanks for the info now i have an excuse to go by a six pack of bud
05-04-2010, 06:51 AM | #12 |
Newbie Join Date: Jan 2008 Location: Roseville
| I was thinking about doing a scaler with a red bull can for side plates, Do they hold up or tear right off? |
