Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Servo Mount and High Clearance Steering Arm
Old 06-24-2010, 07:45 AM   #21
dezmoon's Avatar
are these available yet,,i hit the link and it says out of stock,,,eta on when,,,
dezmoon is offline   Reply With Quote
Old 06-24-2010, 08:59 AM   #22
I havent spoken to Lance much lately....I think his youngest kid (less than one year old) has been requiring much of his time lately. You might try sending him an email...
JeremyH is offline   Reply With Quote
Old 06-24-2010, 10:02 AM   #23
check out JPcustoms
http://www.jpcustomrcs.com/MainMOA.html
toytech93 is offline   Reply With Quote
Old 06-24-2010, 10:19 AM   #24
Originally Posted by toytech93 View Post
I wish they would use the correct terminology--thats a tie rod
crash is offline   Reply With Quote
Old 06-24-2010, 10:19 AM   #25
The homepage has him on vacation until July 6th. Check back then... Thanks
hotrod2 is offline   Reply With Quote
Old 06-24-2010, 11:50 AM   #26
ripper7777777's Avatar
Sorry been sick since saturday.
The shop is currently closed for Vacation and the Holidays until the 6th.
Sorry for any inconvience, but gotta follow the wife's orders....
ripper7777777 is offline   Reply With Quote
Old 06-24-2010, 12:15 PM   #27
What we married guys call "being in the safe zone"
Old 06-24-2010, 01:54 PM   #28
But to avoid confusion, "High Clearance Steering Arm" is what it is called at the beginning of this thread, and it is the exact same part. Jarod is sourcing these from Ripper7777777.
papabash is offline   Reply With Quote
Old 06-24-2010, 09:45 PM   #29
dezmoon's Avatar
no worries,,married my self,,
Old 06-26-2010, 04:50 PM   #30
Ok I am looking at getting this setup but I want to know is. As far as grinding down the tube is can I lay down the servo plate and scribe a outline then take off the plate and grind away? I know I would have to fit the sevo I'm to check for fit. I also want tn know how close to getting into the tube I will be and also how much weight does this take off of heavy set of axles? Thanks
boisetrucker is offline   Reply With Quote
Old 06-27-2010, 11:56 AM   #31
That's what I did when I did mine. I just laid the servo plate in place & scribed a line. Then kept grinding & filing till I was close, then I mounted the plate & fit the servo a few times to get it fitted.
You won't get into the open center part of the tube where the axle is. As far as how much weight gets removed, I don't have any idea. I didn't weigh mine.
hth,
Rich C.
conejo is offline   Reply With Quote
Old 06-27-2010, 12:09 PM   #32
I will let you know what the weight difference is with the cast tubes and the lightweights hopefully by Saturday. I will take some pics and let you know. Scott
hogmansp is offline   Reply With Quote
Old 06-28-2010, 08:11 PM   #33
What pinions are you usin? I just noticed you're using a 9157. I ground down my tube to the point where I have a couple of small hole in my tube and I still can't get the servo in. I'm using 12 t pinions.
Scottmisfits is offline   Reply With Quote
Old 06-28-2010, 08:47 PM   #34
I run the same servo....I did have to bump up to a larger pinion....14T, IIRC.
Old 06-28-2010, 09:54 PM   #35
Iirc?
Old 06-29-2010, 04:47 AM   #36
IIRC = if I remember correctly
Old 06-29-2010, 06:16 AM   #37
Thanks. Just when I think I know all the 'net lingo, something else pops up, lol.
Old 06-29-2010, 11:06 AM   #38
I am running 12 and 12 pinon. Could I get away with a 14 12 or should I just run 14 14 or even 14 13. Also what pitch are the gears again? Thanks Scott.
Old 06-29-2010, 11:13 AM   #39
The motors are independent of one another....you can run whatever pinions you feel comfortable with. Hell, on my old clod 2.2, I used to run a 50T motor up front and a 60T motor in the rear....
Personally, I like my bully to have 1 tooth difference between the front and rear gears....
Old 07-06-2010, 09:01 PM   #40
Finished the install tonight. One of the best steering mods I have seen and works very well
