02-22-2012, 04:37 AM | #81 | |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| re: Stub's Dlux HALLSTYLE Quote:
02-22-2012, 04:43 AM | #82 | |
02-22-2012, 12:05 PM | #83 | ||
I couldnt find the overall axle weight? The gear case you drilled is a LW version? Quote:
My Berg gears are 3.5mm x approx 26mm. I took as much as I felt comfortable and it reduced it 5g. Maybe since youre close to 2x as thick, you would lose 9g? .317oz per gear. Stock 13g Lathed 9g This weighed 1g less then above, 8g Its all in the design. You cant have any stress risers. I seriously doubt you could break my delrin tube on a 2.2. There are quite a few 2.2's running around with zero failures and there are a handful of supers with them on now too. I have taken some serious tumbles with my super and they dont even flinch. | ||
02-22-2012, 01:45 PM | #84 | |
That is one light bully Stubs... Nice driving up in Gainesville too | |
02-22-2012, 03:05 PM | #85 |
| re: Stub's Dlux HALLSTYLE Thank you! Will you be at the comp this weekend? Not sure if anyone is still coming with me, so if nothing else it will be the wife and I.
02-22-2012, 03:08 PM | #86 |
| re: Stub's Dlux HALLSTYLE |
02-22-2012, 10:51 PM | #87 |
02-23-2012, 12:29 AM | #88 | |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
I might have to try the D_luk tubes for the rear. My fronts are obviously not going to be replacable unless I got a custom set. I've actually tried a lower weight, (mid 4lbs) but I just couldn't get a "overall" tire and foam setup that worked well. Perhaps if I can get some time to play this summer I can try again. | |
02-23-2012, 09:02 AM | #89 | |
I look forward to meeting you on Sunday Stubs | |
02-24-2012, 08:26 AM | #90 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
You can always go crazy on the cases Mine: Or even a bit more like this one: I really enjoyed the videos man, great driving! |
02-24-2012, 03:32 PM | #91 |
Wow! Thanks for posting that. There is a ton of material there. Do you have a pic of the case together from the front?
02-25-2012, 06:57 AM | #92 |
No problem, glad you like it! Here's a couple more pictures for you: The case has about 6mm of material there. Now it has 3mm if I remember correctly... |
02-25-2012, 11:14 AM | #93 |
Holy crap there is a lot of extra meat in those cases |
02-26-2012, 10:20 AM | #94 |
Newbie Join Date: Nov 2005 Location: France
Modded the case since 2011 and never have a problem(66gr) Very nice bully Stubs,no reason off switching to berg |
02-27-2012, 02:24 PM | #95 | |
Guys, these look so good I wish you guys were in the US so i could send you a set of cases to work your magic on for me. That is way above my capabilities Quote:
02-27-2012, 02:28 PM | #96 |
02-27-2012, 11:06 PM | #97 |
It's a very very simple job... You just need a burr (it that the right name for it?), and a collum drill and patience Take your time and you'll do it! |
03-01-2012, 06:13 PM | #98 |
Man! I really need a dremel and a lot of patience. I just got a super and those axles need a lot of dremel work with that bit.
03-01-2012, 07:39 PM | #99 |
03-01-2012, 08:42 PM | #100 |
No kidding. What did you get? I got 65:1 axles and a BJ chassis. |
Stub's Dlux HALLSTYLE - Similar Threads | ||||
DLUX 2.2 AND 1.9 wheels | Erik D_lux | Vendors Tires and wheels | 136 | 12-02-2015 08:24 AM |
catpwreds Hallstyle 2013 build | catpwred | EnRoute Berg | 26 | 01-02-2013 10:20 PM |
