01-09-2011, 02:35 PM | #1 |
Newbie Join Date: Dec 2009 Location: Seattle
| Grease for pinion
Hey maybe a stupid question here but what are you using to grease up the motor pinion and axle gears inside your bully's? Also do I need to add grease to the bullies or are they ready to go from the shop? Thanks.
01-09-2011, 03:51 PM | #2 |
Quarry Creeper Join Date: Mar 2005 Location: tuscaloosa
on the rc4wd site it says axles come with no grease in them. I used rc4wd monster lube for my bully axles. I read some use that, rockjelly, or vp 8.0 i believe.
01-09-2011, 03:55 PM | #3 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
Rock jelly
01-09-2011, 04:56 PM | #4 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
Lucus Red-N-Tacky works great and its only around $4 at Auto Zone. It comes on a tube for a greese gun so if you are only using it for RC it will last a life time. It is what most guys run in LCC axles and it works great so you know it will hold up fine in a regular axle.
01-09-2011, 05:26 PM | #5 |
Rock Crawler Join Date: Aug 2008 Location: maple ridge
regular bearing grease with moly in it.
01-09-2011, 09:24 PM | #6 |
Quarry Creeper Join Date: Apr 2010 Location: Hells Hole
I'll second the red & tacky its what i use. Also just a nice thin coat on the gears should do it , you don't want to glob it in there and have it seeping into your motor.
01-10-2011, 12:38 PM | #7 |
Quarry Creeper Join Date: Dec 2009 Location: Nacanowhere Texas
I use the same grease in my bullies that I run in all my axles and to grease my 1.1 Jeep joints and such. Marine grade grease from Advance or Oreilly. It works great!
01-11-2011, 10:16 PM | #8 |
Thanks for all the advice. Much appreciated.
