11-24-2011, 07:08 AM | #1 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| jebster's bully
so i decided to start a build thread. it is very early on but i wanted to keep a record of my progress. i picked up a bully roller in trade and decided to make a basher that my son can abuse. i torn everything down, cleaned it up and started rebuilding. i want to do this fairly cheap so low cost improvements is the goal. so far i've changed up the shocks. drilled the pistons and added mini-t internal springs. the suspension is cycling pretty smoothly. next up is the knuckle mod (once i pick up some bearings). beyond that i need to pick up some electronics to get it running. not much to show but here are a few pics: |
11-24-2011, 08:00 AM | #2 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
Good start so far. While your doing the knuckles, you might as well tear the axles down completely and lighten them up. Check out the tips/trick sticky's at the top. there's tons of good info in there on mods that take almost zero dollars,,,,, just a bit of DIY time. |
11-24-2011, 08:35 AM | #3 | |
11-24-2011, 08:39 AM | #4 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Looks like a good start, and hope your kid likes it. Krakker's advice is good also, those are heavy suckers. |
11-24-2011, 03:20 PM | #5 |
Quarry Creeper Join Date: Nov 2010 Location: Toronto Canada
Very nice, I'll be watching. Buuuutt, I could trade you a scaler or sporty for your kid to bash |
11-24-2011, 06:25 PM | #6 | |
actually he has a maxstone 16 he likes to drive on our backyard course. does pretty well with it but when he gets it into a bind it has broken some parts. he has also driven my sportsman creeper. he does ok but is pretty trigger happy and it scares me. and i don't let him play with my xr10 comp rig!!! bottom line is i want to give him something bigger and more durable so he stays away from my stuff. | |
11-25-2011, 07:35 AM | #7 | |
11-25-2011, 08:45 AM | #8 |
55-65T motors are good as well, you can also change the pinions. I"ve mounted a HPI Jeep body to my Bully before just to do some trail crawling. It's amazxing how just a body change can swing the mood into just having fun VS. "I gotta win". |
11-25-2011, 07:17 PM | #9 | |
you got me thinking about putting a body on my bully. | |
11-25-2011, 07:57 PM | #10 |
13/12 will work good. I've also gone with a 35T/45T motor combo to combat that problem. I like a little more speed when making digs and heating up the tires for a climb so for me a 35T is the choice, 55T's should work just fine for your kids' Bully tho. Perhaps going 12/11 on the pinion would work better for his control. |
11-27-2011, 04:39 AM | #11 | |
another question. i've read about a lot about people clocking the axle to get more caster. seems like people get a jig to drill the new pattern. does anyone sell that jig? and what servo mount would be needed to keep it bta? | |
11-27-2011, 09:40 AM | #12 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
Eritex was selling a jig but he is no longer in business. Still kicking my self for not getting one before he closed down.
12-07-2011, 05:50 AM | #13 |
haven't made any progress lately on this project. waiting to pull together a full set of electronics. i have managed to get a pair of 55T motors and a punk dig. trying to work out a trade for a brxl (keeping my fingers crossed). still need a wantasummit true 3-pos module (i run a traxxas tq 2.4 radio) and a servo, which i want to find a 7950 for a good price. i've had good luck with that servo on my creeper and xr10. i did have a question about wheels. what is the typical vp slw hub offset people run on their bullys? |
12-08-2011, 04:56 PM | #14 | |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
Just an idea. I wish i had the capability to do it. | |
12-09-2011, 04:33 AM | #15 |
| i'm thinking of making my own. just use the existing axle tubes to mark hole patterns on a piece of sheet metal. we'll see!
12-09-2011, 06:53 AM | #16 |
| That's a good idea. Once you aligned the stock holes up on the template you could use a punch to mark the clocked holes. I'm gonna try that and see if I can come up with something.
12-10-2011, 05:05 AM | #17 |
dumb question. what hex hubs would people recommend for the rear axle? my rig was missing one and i want to order up a new set.
12-16-2011, 06:46 PM | #18 |
| play in the front axle?
i'm making slow progress but progress. got the front axle back together. did the knuckle mod (flanged bearings) and it feels strong. but now another issue. it seems there is a lot of play in the axle. if i hole one wheel i can turn the other wheel 30*. i can see the transmission gears are spinning when i do that. it is the same either wheel i hold. suggestions?
12-16-2011, 07:41 PM | #19 | |
| Re: play in the front axle? Quote:
Until you get it apart, you'll never know for sure. | |
12-16-2011, 07:44 PM | #20 |
| Re: jebster's bully
i figured it was something like that. hate having to pull it all back apart after just getting it together! |
