06-09-2012, 03:52 PM | #1 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
| My cheapo sng build
Getting back into a comper, but going cheap to start with... Hitec 7950 cc bec dual mamba micros 4s EEM SNG HC chassis Hammered BC's Eritex wheels with Integy hubs up front narrowed axials in back 45t's Shaved rear tubes, LW. eritex wheels with integy hubs, tire to tire is a bit wide at just under 11.5. Im work on it though. |
06-10-2012, 01:30 PM | #2 |
| Re: My cheapo sng build
Got her into a roller. Ended up running Berg offset Eritex rims up front with integy hubs, 10-3/4 now. |
06-12-2012, 12:21 PM | #3 |
Thats a good looking start! Keep it up |
06-12-2012, 01:06 PM | #4 |
| Re: My cheapo sng build Thanks... Can someone help me do some math? The hubs Im running are Integy +10mm, that eliminate the hex. With these rims up front, Im at 10.75". But I want to go to some slw hubs so I can use my v6 shafts. What offset hub should I get? Im wanting them to be hub and hex about the same as these 10mm hubs. Id like to stay under 11". |
06-12-2012, 01:53 PM | #5 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
10mm is equal to .3937"
06-12-2012, 03:47 PM | #6 |
A 225 hub stacked on a V6 hub is approx .440 from hex pin hole to hub face.
06-14-2012, 10:58 AM | #7 |
Thanks for the measurements guys. The Integy's are working great from me so far though so Ima wait. Got it wired yesterday and ran it for a pack. Sure am glad to be back into crawling. My hella hacked lid lol. Prolly pick up something new soon. |
06-15-2012, 11:14 AM | #8 |
Did some real quick and real ugly cut n shuts for the front.... |
06-15-2012, 11:42 AM | #9 |
Ugly hell. You might be onto something. I have seen the leopards do some amazing things, except for side hill because of the week sidewalls. The sedona may give it the support it needs. Nice work.
06-15-2012, 05:02 PM | #10 |
Here they are mounted up, using an old lid too....messed around with the rear tires too... |
06-15-2012, 09:32 PM | #11 |
Ran it for a couple packs, heres a pic out doors lol....rear tires didnt last too long with the new lugs added lol.... |
07-15-2012, 05:49 PM | #12 |
Got some hex's made by CREEPERBOB for my v6 shafts so I didnt have to order them from rc4wd. With them and 600 hubs on these eritex berg offsets, Im sitting at 11.25 front, just perfect for me. Also made a couple new rear wheels today as well as new links and swapped to a SNG bodiless. |
07-15-2012, 05:54 PM | #13 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Looking good , glad the hexes worked for you .
07-15-2012, 07:30 PM | #14 |
Yep work perfect man, thanks!
My cheapo sng build - Similar Threads | ||||
abadk9420's SNG Shafty Chassis Build | abadk9420 | Axial AX-10 Scorpion | 17 | 01-18-2011 10:08 PM |
SNG Bully Build | slowngreen | RC4WD Bully | 142 | 05-29-2010 08:19 PM |
Jim's EEM SNG Berg Build | vincentvega | EnRoute Berg | 9 | 05-07-2010 12:12 PM |
H8z2luze's EEM SNG Berg build | h8z2luze | EnRoute Berg | 56 | 03-03-2010 04:09 PM |
project el cheapo | sloppy | General Crawlers | 44 | 02-02-2007 06:42 PM |
