07-02-2014, 09:55 AM | #1 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Remedy Bully2
So I jumped into the band wagon as well..... Bought this beauty here after selling my SA XR10. The spec Bully2 Diff with knuckle weight and steering kit; Remedy 3.5 Chassis; HH Puller 400 motors 30T; Dual BR-mini and BEC; 7950 Servo; Ti lower link and alu uppers; Creeper Bob Rear Ti Axle; NCD Battery Mount, servo mount and electronics tray; Kyosho Velvet shocks; YTC 3 pieces wheel with Voodoo Silver and CI Foam; 4pls; It weighed at 4.1lb (4.005 lb plus battery).... Not to bad consider it has all steel hollow balls and steel hardware, my aim is to lower it to sub 4 lb. I am in the process of rebuilding it, I rebuild the shock, added a bladder and 50wt rear and 30 wt front. Also change the rod end so it is 90mm now and allow me to fit it up side down to lower the CG. Any comment welcome... Last edited by Colgout; 07-02-2014 at 10:01 AM. |
07-02-2014, 04:27 PM | #2 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
| Re: Remedy Bully2
I would redo the top skin to cover the carbon fiber and protect it. Otherwise you'll wear through it, or worse, shatter it and splinter it.
07-02-2014, 04:27 PM | #3 |
| Re: Remedy Bully2
more pics too please. Like front and underbelly, etc.
07-02-2014, 07:42 PM | #4 |
| Re: Remedy Bully2
I don't have any more pic, the rig was dissembled as soon as I got it.... Today I am reworking the link to suit, the dimension is based on Cboggs' info, I like his father's remedy stance, so I will try to do the same. I basically need to move the chassis back about 5mm. Does anyone have any idea to make a motor protector for the puller 400? |
07-02-2014, 09:09 PM | #5 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
| Re: Remedy Bully2
Good rig you picked up, just let me know if you got any questions. |
07-03-2014, 03:38 AM | #6 |
I wanna be Dave Join Date: Nov 2005 Location: Here
| Re: Remedy Bully2
Welcome to the REVOLUTION!!!
07-03-2014, 11:06 AM | #7 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
| Re: Remedy Bully2 Yes welcome Now enjoy Thinking with some Alum balls and screws also change to some scx 10 shocks and you will be sub 4Lbs no problem. Last edited by chevotafun; 07-03-2014 at 11:09 AM. |
07-03-2014, 11:17 AM | #8 |
| Re: Remedy Bully2
Dammit. I just noticed that u got some bada $$ motors with that too!
07-07-2014, 01:59 AM | #9 | |
Quarry Creeper Join Date: Feb 2014 Location: Chapel Hill, NC, USA
| Re: Remedy Bully2 Quote:
Spiitz' Bully 2 build a.k.a. "Hammond" You can also pickup Delrin motor savr's from HH but they would need to be modified to fit your smaller can anyway. Good looking rig! | |
07-07-2014, 03:38 AM | #10 |
| Re: Remedy Bully2 |
07-07-2014, 10:21 PM | #11 | |
07-07-2014, 11:33 PM | #12 |
| Re: Remedy Bully2
A bit of update. Links. Replaced steel screw with Ti and alloy (where possible) saved me 8 g at the front end. I also replaced the alloy post of the NCD tray with nylon one. Back end will be less as there aren't many screws that can be replaced. Also replaced all hollow balls with alloy one. On jig its a roller now... Full height Fully compressed Can drive upside down even with the small panther tire.... Next, I want to clock the front a bit more, so the tray is out of the way. and the spring feel a bit too stiff. But I will do them when its a runner. Need to sort out the motor and electrics. Last edited by Colgout; 07-08-2014 at 12:06 AM. |
07-08-2014, 11:23 AM | #13 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
| Re: Remedy Bully2
Looking good mate, I have 5 new motor sav'rs in the jeep if you need a couple |
04-11-2015, 08:19 PM | #14 |
| Re: Remedy Bully2 |
04-11-2015, 08:40 PM | #15 |
Rock Stacker Join Date: Dec 2006 Location: Crofton, Maryland
| Re: Remedy Bully2
Where did you get that jig? Sent from my iPhone using Tapatalk |
04-15-2015, 06:52 PM | #16 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
| Re: Remedy Bully2
Why did you change the shocks?
04-16-2015, 03:34 PM | #17 |
Stephan Hauser / # 7 Join Date: Apr 2012 Location: Germany
| Re: Remedy Bully2
Rig and pictures are looking good. Nice to see one more Remedy here |
04-16-2015, 10:45 PM | #18 |
| Re: Remedy Bully2 A local guy made it. they are for sale in onetencrawlers.com.au... But I think it out of stock atm. contact them that you are interested in one. I reckon the velvet shock is a overkill in a crawler that weight 4lb and does not jump. So I move them to my Ultra4 rig that weigh 7.5 lb and does occasionally jump.... Thanks. |
04-23-2015, 01:54 PM | #19 |
Rock Stacker Join Date: May 2013 Location: Sweden
| Re: Remedy Bully2
What tires are you using?
04-24-2015, 10:41 AM | #20 |
| Re: Remedy Bully2 |
Remedy Bully2 - Similar Threads | ||||
roxx bully2 | roxx | RC4WD Bully | 111 | 09-19-2019 05:11 AM |
g-jero,s Bully2 | g-jero | RC4WD Bully | 21 | 05-11-2015 08:45 PM |
Remedy Bully2 for my dad... | cboggs | RC4WD Bully | 48 | 11-16-2014 01:12 PM |
Few things about the Bully2 | Colgout | RC4WD Bully | 6 | 01-30-2014 11:52 PM |
