Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: reviews
Old 06-14-2017, 09:53 PM   #1
Default reviews
I've looked all over the place for reviews on the B2 axles. So is anyone willing to share their thoughts? Also, is there anyone out there that went from bergs to B2s?
Dezertdirt is offline   Reply With Quote
Old 06-16-2017, 08:54 PM   #2
Default Re: reviews
Really 55 people looked but weren't willing to say anything. Did 55 people just have the same question?
Old 06-16-2017, 11:43 PM   #3
Default Re: reviews
I like mine. Other then a few known issues, there legit and solid. I haven't had any major problems.
84yoda is offline   Reply With Quote
Old 06-17-2017, 06:50 AM   #4
Default Re: reviews
Roger that, they also have more pumpkin clearance Clarence.
travis c. is offline   Reply With Quote
Old 06-17-2017, 08:33 AM   #5
Default Re: reviews
Dezert, are you interested in the B2 axles? If so, buy a B2 front axle then build a rear with krazed builds KR4 carbon fiber/delrin housing. That will eliminate some failures and is a huge upgrade over stock B2 axle.
Old 06-17-2017, 09:43 AM   #6
Default Re: reviews
The only issue them are the cheap junk Chinese bearings that fail and cause one of the small idlers to break.
Swap out them for some Fast Eddie bearings and the pretty much bullet proof as any other axle out there
Tom G is offline   Reply With Quote
Old 06-17-2017, 12:01 PM   #7
Default Re: reviews
So I already have a set of lathed down berg v1s with xr shafts, and they are very heavy. It's time for a major update. After looking at berg parts I realized that What I wanted to do would cost about the same as going to B2 front and kr4 rear. So should I go B2 and kr4 or upgrade the bergs? Thanks everyone.
Old 06-17-2017, 01:06 PM   #8
Default Re: reviews
Check out Zarizi Tech's Bully 2. RC4WD Bully 2 a.k.a Koppensneller
He seems to be doing pretty well with it.
Tossedman is offline   Reply With Quote
Old 06-17-2017, 01:35 PM   #9
Custom Carbon Fiber
Robbob's Avatar
Default Re: reviews
TomG has some in the for sale section last I looked.
Really the best bang for all the dollars right there
Lot of people are having good luck with them, you just dont see it much here anymore because people dont do build threads any more
Robbob is offline   Reply With Quote
Old 06-17-2017, 02:44 PM   #10
MODERATOR™
EeePee's Avatar
Default Re: reviews
Might have been your vague thread title. It could be taken in a few different ways that 55 people thought would be a different thread.
EeePee is offline   Reply With Quote
Old 06-18-2017, 12:22 PM   #11
Default Re: reviews
I have my bully2 for over 3 years now i didn't have any issue with it . I opened the gear boxes just before the nordics for the first time in 3 years and nothing is damage on the gear or bearing i still run them from out of the box front and rear . Before i had xr10 axles and they keeped breaking gear and bearing. so for sure the bully2 are very good out of the box . If your budget allowed you to get a kr4 rear axles do it but it's not obligate . The bully 2 axles front and rear placed 3rd at the last world's . So for 100% they are good
roxx is offline   Reply With Quote
Old 06-18-2017, 01:10 PM   #12
Default Re: reviews
Bully 2 here, too.
No probs so far, top notch for 2.2 modified class!
Rockatanski is offline   Reply With Quote
Old 06-18-2017, 03:47 PM   #13
5th D Owner/Driver
cboggs's Avatar
Default Re: reviews
I replace my bearings every year as preventive maintenance. The only time I've munched the idler gear is after more than a year of abuse and the bearing takes it out. No axle on the market should be a run forever and never do maintenance. I also run the KR4 rear as it weighs nothing and tucks the motor nice and tight to the axle tube.
cboggs is offline   Reply With Quote
Old 06-19-2017, 01:00 AM   #14
Default Re: reviews
I also run these axles more than 3 years and they did a great job Price performance ratio is perhaps the best on the market!
You just should note some things:
As Chris Boggs said, to replace the bearings is not wrong,these are cheap and especially the small ones (5x9x3) are not for a liftetime.Best choice for the rear axle is the KR-4,very lightweight,motor close to the axle and you donīt have the small bearings like mentioned above!
Another important thing: you should always put some grease or oil to the XVDīs never run them dry! Itīs very easy to disassemble them:
And a very good upgrade to remove high forces from your servo is a longer steering arm,you can build it by yourself or also buy it for a low price from X3M-Crawl
But if you crawl with a clear brain and donīt violate your crawler itīs not a must-have If you look at these things,the axles are extremely durable
Snatch is offline   Reply With Quote
Old 06-20-2017, 12:00 PM   #15
Default Re: reviews
Love my Bully 2's, super strong and reliable, and yes defenitly get the KR4 rear diff.
chevotafun is offline   Reply With Quote
Old 06-20-2017, 11:26 PM   #16
Default Re: reviews
What is this KR4 rear y'all speak of?.....
Thrifty is offline   Reply With Quote
Old 06-20-2017, 11:50 PM   #17
Default Re: reviews
KR4 Rear Axle
Old 06-21-2017, 02:18 AM   #18
Default Re: reviews
So is it a no brainer easy procedure to swap your stock internals into the KR4?
cloudswimmer is offline   Reply With Quote
Old 06-21-2017, 08:48 AM   #19
5th D Owner/Driver
cboggs's Avatar
Default Re: reviews
Easy, everything transfers right over into the new housing.
Old 06-21-2017, 09:12 AM   #20
Custom Carbon Fiber
Robbob's Avatar
Default Re: reviews
Uses all the original axle bearings except the little one that blows up, stock gears are used and the stock axles slide right in. All you need is a donor complete axle or buy the axleshafts, bearings and gears (when they finally get instock) seperately.
reviews - Similar Threads
Any reviews or help on this Rc brodie Newbie General 4 05-20-2017 12:28 AM
anyone seen this?/reviews mtnbiker93 Newbie General 3 02-12-2010 01:44 PM
Charger - Reviews / What to look for Notpalc Newbie General 14 12-19-2009 10:20 PM
does anyone have any info or reviews about these? scale4x4 Electronics 9 08-20-2009 01:10 PM
Reviews Pdog7 Comments, Suggestions, and Help 1 02-10-2009 06:47 PM
