07-30-2014, 12:47 PM | #1 |
Pebble Pounder Join Date: Mar 2012 Location: Greece
| Wanted Bully V1 Battery mount behind the front motor
Does anyone know where can I get a battery mount to fit bully axles-gearbox? I used to play with big batteries so I need something strong. Thanks |
07-30-2014, 05:01 PM | #2 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| Re: Wanted Bully V1 Battery mount behind the front motor
For the bigger batteries I found the chassis battery mount, like the t1e ss chassis, work a bit better and have more room. I could fit a 1300mah in there with outboarded upper links up front.
07-30-2014, 05:27 PM | #3 | |
| Re: Wanted Bully V1 Battery mount behind the front motor Quote:
I have seen Rowdy Racing mount behind the axle but I think it is more a mount for electronics than for batteries. | |
07-30-2014, 05:42 PM | #4 |
| Re: Wanted Bully V1 Battery mount behind the front motor |
07-30-2014, 06:25 PM | #5 |
Quarry Creeper Join Date: Nov 2013 Location: Pittsburgh
There is enough room in the cases that you can drill two holes and bolt a piece of carbon, delrin or G10.
07-31-2014, 05:46 AM | #6 |
07-31-2014, 09:16 AM | #7 |
07-31-2014, 03:32 PM | #8 |
The vendor support was limited on these axles. They mostly appealed to guys that like to make stuff their own way.
07-31-2014, 05:28 PM | #9 |
there is lots of room in them gear cases that you can drill holes in it and cut a piece of some material to make your own mount. here are a few pictures as to where to drill. There is a TON of material that can be removed to save weight on these axles. the tubes alone can be drilled out to 3/8". I drilled out the short side tube on the super bully axle and it took off 10 grams just off the short side. the long side of the super bully would be more. the weight saving wouldn't be as great on the regular bully axle but still a great deal. |
08-01-2014, 12:48 PM | #10 | |
08-01-2014, 01:05 PM | #11 |
08-01-2014, 01:18 PM | #12 |
08-01-2014, 01:25 PM | #13 |
| Re: Wanted Bully V1 Battery mount behind the front motor I think the xr flipped upside down was most popular on bullies, maybe someone with experience will chime in.
08-01-2014, 02:09 PM | #14 |
08-01-2014, 03:03 PM | #15 |
If you are drilling holes in the gear case to mount the mount any mount will work as long as it fits between your links and don't hang down to low. Find out the dimensions of the mounts and cut a piece of cardboard that size and tape it in place to make sure you have enough room and nothing hits or binds.
08-21-2014, 05:54 PM | #16 | |
Thanks for the idea. | |
Wanted Bully V1 Battery mount behind the front motor - Similar Threads | ||||
Bully 2 battery and electronics mount?? | tweak6 | RC4WD Bully | 1 | 04-06-2014 10:15 PM |
Mount battery up front or back | insutama | Axial SCX-10 | 17 | 03-26-2014 10:11 AM |
stick battery mount up front | ranover | Axial Wraith | 2 | 07-13-2013 04:23 AM |
Does this mount the battery in the front ? | RazBarlow | HPI Wheely King | 1 | 05-16-2009 11:53 AM |
Battery mount over front axle how to? | grimgard | Axial AX-10 Scorpion | 20 | 10-27-2008 12:09 PM |
