Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Bully 2 tapped holes expose internals...
Old 09-02-2014, 11:38 AM   #1
Default Bully 2 tapped holes expose internals...
I can't find any information on this. I have found a few tapped holes on the axle that expose the gears. What holes are tapped through to the gear/axle housing? Is this manufacturing defect?
Thanks!
infodragon is offline   Reply With Quote
Old 09-02-2014, 01:40 PM   #2
Default Re: Bully 2 tapped holes expose internals...
For what they are made for it is of very little concern. Comp crawling is usually very clean thing. If it is a problem put cool stickers over them.
josh6575 is offline   Reply With Quote
Old 09-02-2014, 01:42 PM   #3
Thanks for the confirmation!
Old 09-02-2014, 02:20 PM   #4
Or, put a short screw in it.
Tossedman is offline   Reply With Quote
Old 09-02-2014, 06:48 PM   #5
those holes are the godsend. If everyone made every thing like that, I wouldn't have to drill so much.
Master Basher is offline   Reply With Quote
Old 09-03-2014, 09:46 AM   #6
I have done this! Thanks!
I couldn't agree more! This was one of the reasons I went with the Bully 2!
Another issue I'm having is that the rear axle is making a ticking sound in reverse. I've pulled it all apart and verified everything is tightened and lubed up. It sounds as if one of the bearings is wore out; I would not suspect this with a new set of axles.
1. I pulled both the axles off and it's definitely coming from the gear box.
2. Pulled the motor off and the sound is not coming from the motor.
3. When the motor pinion is pushed extremely tight against the gear the ticking goes away, however this is too much strain on the motor shaft. Also it takes 3x as much torque to spin the tire (this was measured using the extremely accurate spin the tire with your hand method.)
Any suggestions before I contact RC4WD?
Thanks!
Old 09-20-2014, 08:29 PM   #7
when you pulled the axles, how did you turn the gears? with the motor?
if so did you try turning the gears by hand after you pulled the motors off?
can you correlate the ticking sound to the rotation of any specific gear?
maybe a burr or something on a gear?
inquiring minds want to know
(or it could be one of the newest version of the axles with a reverse warning mechanism
to warn other people when you are backing up so they wont get hurt)
cabron is offline   Reply With Quote
Old 09-21-2014, 12:54 PM   #8
The reverse ticking is coming from a slightly "off" bearing, they all fell out, 3-4 inches, when I pulled the cover and I made sure they were free of debris and put them back. I'm assuming they all didn't make it back in the same place with the same orientation so one slightly out of tolerance may be ticking now.
As to the ticking, it only happens when I have the motor connected, can't replicate by hand (not enough rotational velocity.) Only if I mount the motor very tightly against the gear does it stop, however it is too tight and is bound up (Only did this for a few seconds to test)
I am suspicious of the middle of the three main gears. If it gets much worse I will replace the gears, for now I don't do a lot of backing up and the ticking is very very minor.
Old 09-21-2014, 04:47 PM   #9
Did you happen to try a different motor? Might be the motor bearings or brushes doing strange things.
Old 09-21-2014, 06:08 PM   #10
if you have the inclination, start swapping out gears and/or bearings out with the front axle until the noise
moves to the other axle.
did you try swapping out the motors?
second on the brushes under some load
Old 09-21-2014, 06:42 PM   #11
keep an eye on this bearing ;
nappahdog is offline   Reply With Quote
Old 09-21-2014, 06:47 PM   #12
Replace all the bearings with quality bearings first thing when running these axles and you should be gear problem free!
ROWDY RACING is offline   Reply With Quote
Old 09-21-2014, 06:56 PM   #13
yeah it was a mistake to trust the stock china bearings, maybe 120 minutes drive time on those axles :(
no dust inside from the holes though haha
Old 09-22-2014, 01:14 AM   #14
I´m very surprised about this
I drive these axles round about 1 year.At first i took apart all components and put some grease (specially for transmission) to it,then i put it together,all screws with some loctite.That was it.No problem with anything, i really love these axles
I drove some comps and many many Lipos,you can see it here,the bottom of the axles are no more black
But good to hear,if i will change the bearings sometime i will better get a proven quality
Snatch is offline   Reply With Quote
Old 09-22-2014, 05:36 AM   #15
Tried different motor, reversed polarity on the existing motor as well. Clicking did not "follow" the motor reversal, it was in the same direction.
Old 09-22-2014, 05:38 AM   #16
I will probably do this over the winter when there's snow everywhere and I'm jonesing for some RC crawling action.
Bully 2 tapped holes expose internals... - Similar Threads
Bully 2.2 internals 5699 RC4WD Bully 15 08-27-2012 09:24 AM
Pls help: motor plate holes won't fit with tekin motor holes painter4x4 Axial Wraith 11 02-04-2012 08:06 AM
Tapped out!!! JIA's Dad Chit Chat 17 03-12-2009 07:54 PM
