02-05-2016, 06:19 AM | #61 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: Hulksta Riddler
Doesn't look like you are using the internal shocks in that pic Dan....and a different nose? Is that old? I prefer the screw down approach |
02-09-2016, 07:04 PM | #62 |
RCC Addict Join Date: May 2012 Location: Montreal, Qc
| Re: Hulksta Riddler
RC4WD Bully tires on the way Last edited by noname0383; 02-11-2016 at 10:02 AM. |
02-11-2016, 07:20 PM | #63 |
| Re: Hulksta Riddler
Found a bit of time to work on this build... Dravtech cf servo mount and Savox servo installed... front HH crawlmaster expert too... Rear HH crawlmaster Expert RC4WD internal spring kit for 1 of the ''in board'' shocks... I used the stiffer one... Now for those who run this chassis, what oil wt did u used for the 2nd ''in board'' shock??? I was thinking about 50-60wt... |
02-11-2016, 11:03 PM | #64 |
RCC Addict Join Date: May 2012 Location: Folsom
| Re: Hulksta Riddler
Im not running this chassis, but my thought would be to run thicker than that. That way the feature only articulates when it absolutly has to. This should allow for some rear push if needed without shortening your wheel base too much. Just my thought tho. My guess somewhere between 80wt and 100wt |
02-12-2016, 12:06 AM | #65 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
| Re: Hulksta Riddler
^^^ Yep So you want the main shocks doing their job and reaching max before the feature starts to work, and even then you want it smooth... I used 10,000wt diff oil in mine ;) but that was single setup, and i felt like stepping up to 15,000wt |
02-12-2016, 04:41 AM | #66 |
| Re: Hulksta Riddler Bully 2
As for the shock i just picture, Is it the right way to mount it? I used the stiffier spring in the kit... Envoyé de mon LG3 avec Tapatalk |
02-12-2016, 06:44 AM | #67 |
| Re: Hulksta Riddler
That's what I did, although I did not use any oil in those shocks...just the internal spring. I haven't had the luxury of a shake down run yet to see how this works....this may all change. Hopefully you don't need a stiffer spring than what's in that kit....don't know where you'd find one. Did you put 10k wt oil in the main shock Dan? One question..are the rc4wd pins narrower than the Voodoo's? |
02-12-2016, 07:15 AM | #68 | |
| Re: Hulksta Riddler Quote:
02-12-2016, 07:16 AM | #69 |
| Re: Hulksta Riddler
And with proper CI foam, they are a even bit narrower then my last pic...
02-12-2016, 07:29 AM | #70 | |
10K in at least 1 of them will make a smoother motion... | |
02-12-2016, 11:59 AM | #71 |
| Re: Hulksta Riddler
Aluminium blue hardware ordered... ;)
02-12-2016, 02:28 PM | #72 | |
Haven't had any time for crawling lately...will try to get a shake down this weekend and figure out what I need from there... | |
02-13-2016, 07:18 PM | #73 |
| Re: Hulksta Riddler
Went with 120k diff oil in my second inboard shock... very smooth motion in combinaison with the first shock with only an internal spring in it... |
02-18-2016, 06:33 PM | #74 |
| Re: Hulksta Riddler
Ohhhhhhhhhhh RC4WD Bully tires RC4WD Bully2 bearing upgrades kit And some blue alu hardware from Fastener Express, mainly for the beadlocks... |
02-18-2016, 06:41 PM | #75 |
Quarry Creeper Join Date: Aug 2015 Location: canton,oh
What inboard shock you using? Mine is single shock and I ordered a losi mini and it just fits. But is to short so any link or part number b great. Sent from my XT1565 using Tapatalk |
02-18-2016, 07:01 PM | #76 |
| Re: Hulksta Riddler
Single and dual inboard shocks are different... not the same lenght at all... Mine is the dual inboard and i run 2x scx10 90mm shocks... For the single, i think it was something around 70-75mm... But ask Dan @ Hulksta... He can provide the right information or u can buy the new dual inboard shocks ''hood'' at a cheap price... |
02-18-2016, 07:05 PM | #77 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
| Re: Hulksta Riddler
Great job in matching your shoes to your dress |
02-18-2016, 07:09 PM | #78 |
| Re: Hulksta Riddler |
02-18-2016, 07:12 PM | #79 |
I sent Dan a pm a day or so ago haven't heard back yet. I would be interested in a cheap upgrade to duels . or at least a link I really wanna drive this thing lol Sent from my XT1565 using Tapatalk |
02-18-2016, 07:16 PM | #80 |
| Re: Hulksta Riddler
Yeah Dan is VERY busy right now, he is currently developing new pretty cool upgrades for the Bully2 axles... You may try his FB page or here: Riddler Pro Chassis |
Hulksta Riddler - Similar Threads | ||||
Hulksta Riddler with a dash of Dlux | filotr14lsdude | EnRoute Berg | 43 | 11-08-2015 04:27 AM |
The Riddler from Hulksta Engineering | Hulksta | Videos! | 3 | 01-30-2015 05:21 PM |
Riddler. | YoUnG_vErSiOn | 2.2 Scale Rigs | 10 | 10-05-2012 08:28 PM |
