Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: newb bully 1 build
Old 01-15-2016, 08:47 PM   #1
Default newb bully 1 build
hi i have took a good deal on bully 1 axle and will build something around,it will be a slow thread but any help and advise will be really appreciated.for now i have put them in parts for the cleaning and some mods on so if people still have pics and comment on how they have done their one put them here,i am in reading some build thread but sometime the pics are no longer available.so i am not easy with build thread and could seem to have many question at same time but i would try to have answer soon to began soon.
for now the parts i have is
-hitec 7950
-cf Wheel with Voodoo on and ci foam
-near complet bully axle set plus another set of gear box and gear
-castle creation sidewinder 1/18
-1 hh motor 35t(the sticker on is blue but don't remember exactly)
-scx10 shock with some spring
-2 bodies 1 xciter and 1 xr10 with a nice paint
what i will need
-a chassis don't know what i will took i have fews model i am looking but due the cad dollar at this time i will attend, but i have a Buddy here that can send me a mark2 chassis and i am looking to make my own too,but i will focus more on electro and motor
-1 or 2 motor for now i have to look what work good for those axle and the pinion for too
-ccbec 10 amp
so my first question is about electro what i could use with one sidewinder esc that can work with my Spectrum dx3c????what drill bit you have use for drilling gear,bit used for case shaving and modding.about motor and pinion from the guys that have run bully 1 axle with today product what are your sugestion for motor and pinion????
thanks to all that ,and all comment are welcome
pyranahryder is offline   Reply With Quote
Old 01-16-2016, 03:19 PM   #2
Default Re: newb bully 1 build
A good carbide drill bit will get you through the gears. If you can find a punk dig it will work well as long as you don't switch under a high load. If using only one esc. I liked using a 13T pinion up front and 12T rear. 30 to 35 turn motors work great. Check this thread out. I made sure the pics still show. Ugly truckling build
josh6575 is offline   Reply With Quote
Old 01-16-2016, 04:16 PM   #3
Here is another good thread to read. Bully PRO's. "Letting the Cat out of the bag"
Old 01-16-2016, 09:15 PM   #4
ok thanks i will take a look at those build.
how work the punkdig and does i can find it anymore i it is just used i will????
Old 01-17-2016, 01:00 PM   #5
http://store.rc4wd.com/Rocker-Dig-II...er_p_1321.html
Old 01-17-2016, 01:49 PM   #6
Or the Punk dig Dig Switch 3D (3rd Channel) Punk RC Dig Switch [DigSwitch-3RD] - $69.00 : Zen Cart!, The Art of E-commerce
If you decide to run one esc I think the 1/18 sidewinder won't be enough. Mamba Max would probably be better for two motors.
Heido is offline   Reply With Quote
Old 01-17-2016, 07:07 PM   #7
ok ok i will have to do a little work search on about what i will do for the esc but what could are my other option for an dx3c????i know novak m2dig i have got one in my first moa and was working good but big a little bit.
newb bully 1 build - Similar Threads
Master Basher's second Bully build (bully 2) Master Basher RC4WD Bully 51 06-27-2014 10:12 PM
Modified Old LCC Shafty or Newer MOA Bully for a NEWB? CreepyCrawler420 Newbie General 7 10-11-2013 08:38 PM
My 1.9 newb build :) ScGRaceR 1.9 Scale Rigs 34 06-10-2007 11:52 AM
Another Newb. Build trussman Tamiya TLT Crawlers 18 05-07-2007 02:55 PM
Newb Build not quite! cblake187 Tamiya TLT Crawlers 38 01-14-2007 06:55 PM
