06-01-2016, 05:57 PM | #21 |
Pebble Pounder Join Date: Mar 2008 Location: Wallingford, CT.
| Re: RC's Bully2 / SuDu 3D Build
Also trying to build a better shock. This design is a two pcs, has an inner & outer shock body. There are holes in the inner body to control the flow of oil around the inside diameter of the outside body. This will be adjustable in the next set, but right now it has no holes in the piston, it just ride with the oil. [/URL] [/URL] [/URL] Mine weight in at 7grams, but I'll work on that. And the second adjustable set will be tune able on the fly. [/URL] Scx10 stock weights 6grams. [/URL] |
06-01-2016, 06:19 PM | #22 |
Got my Dravtech Bully CF axle parts in the mail. Fast shipping, great parts, awesome job. [/URL] [/URL] |
06-01-2016, 07:37 PM | #23 |
Rock Crawler Join Date: May 2007 Location: Norwich
| Re: RC's Bully2 / SuDu 3D Build |
06-01-2016, 09:09 PM | #24 |
Rock Crawler Join Date: Dec 2010 Location: Ct.
Can't wait to see how those shocks work, they look cool as hell!!! Nice work! |
06-01-2016, 09:11 PM | #25 | |
| Re: RC's Bully2 / SuDu 3D Build Quote:
And they're the same size as SCX10 shocks Last edited by ROCKCRUISER; 06-01-2016 at 09:12 PM. Reason: Added sent | |
06-01-2016, 09:14 PM | #26 |
06-03-2016, 07:56 PM | #27 |
Ok update on the inner wheel weights / carbon fiber beadlock rims Got a lot of work done but still have some to do, What's left nylon stand offs, aluminum hardware, lighting holes in the Carbon Fiber and finish the weight inserts themselves. Tell me what you think! [/URL] [/URL] [/URL] [/URL] [/URL] [/URL] Last edited by ROCKCRUISER; 06-03-2016 at 07:59 PM. Reason: Added sent |
06-04-2016, 08:44 AM | #28 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
Very nice! So you will still have a true beadlock system right? |
06-04-2016, 08:50 AM | #29 |
Quarry Creeper Join Date: Jan 2014 Location: Western Wa. Mose Capital of the World
Nice work!! really nice to see someone actually pushing the design envelope and machining some of his own parts. |
06-04-2016, 10:20 AM | #30 |
| Re: RC's Bully2 / SuDu 3D Build Yes it will be a true beadlock. I did a quick test w/voodoo pins and just three pan head screws held the front tire in place. Still have a lot of work and engineering to do, but the 1st design is working well. Going to make a back beadlock as well, just much smaller on the ID CF ring Thanks for the kind words! |
06-04-2016, 10:33 AM | #31 | |
Hoping to get these a little more compact and lighter & still be able to run down to a 1/2 width. Right now everything is 2mm CF, but I think I could use 1.5 & still contain enough strength. The outer diameter is a little big right now, still has room for foam, but the next set will be smaller allowing for better tuning. Right now there is 1/2 of foam in between the ring and the tire & a 1/4 on each side. But when I'm done there should be over 3/4 in between & over 3/8 on the sides. But the weights are really really low in the rim/tire. Can't wait to some testing on the rocks. | |
06-04-2016, 03:42 PM | #32 |
I also have a similar design to that. To mount the tires I just have 4 tabs/screws and you have 6 (or 3..). I was cutting the lip of the tire to get over the tabs and make it a beadlock. I replaced all of the inner foam in mine. If I would go fast it would bottom out but in slow crawling it was fine. |
06-04-2016, 04:37 PM | #33 | |
06-06-2016, 02:34 PM | #34 |
Teaser! New bully 2 part! [/URL] |
06-06-2016, 02:59 PM | #35 |
There it is new bully 2 hub adapter. Making them with a 14mm pin and a 12mm. Then testing see what works better. Ordered alloy pins from mc-master carr. They should be here tomorrow. [/URL] [/URL] And yes I know the pin slot is not complete lol |
06-06-2016, 03:59 PM | #36 |
Got some more sweet parts in the mail today! Big thanks to Dlux for some sweet Ti links. They look awesome! [/URL] [/URL] |
06-06-2016, 07:59 PM | #37 |
Little update on the internal wheel weights Super secret Ninja stuff going on here! LOL [/URL] Got the brass inserts made thinking I'm going to make a solid brass weight that sandwiches the carbon fiber might be easier to handle. |
06-06-2016, 08:05 PM | #38 |
That's some serious BLING!!!!!! |
06-07-2016, 08:01 PM | #39 |
Made a another weight today she's a little heavier than the slugs. [/URL] [/URL] [/URL] |
06-13-2016, 08:17 PM | #40 |
Just a little update, got a new steering arm made today along with a couple king pin bushing, one 2mm longer & a one 3mm longer depending on what size carbon fiber I use to make the steering arm. [/URL] [/URL] [/URL] HERE'S A LITTLE TEASER, WHATS THAT! [/URL] |
RC's Bully2 / SuDu 3D Build - Similar Threads | ||||
Dlux/sudu build | FLOKI-81 | EnRoute Berg | 162 | 06-17-2016 12:28 PM |
Hustler's Sudu Build | stankulas | Axial AX-10 Scorpion | 13 | 05-09-2015 07:11 PM |
Looper's Bully2 Build | Looper | RC4WD Bully | 19 | 10-10-2014 07:35 PM |
Papabash's Bully2 Build | papabash | RC4WD Bully | 54 | 05-16-2011 08:54 PM |
