Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: RC's Bully2 / SuDu 3D Build
Old 06-16-2016, 08:07 PM   #41
Default Re: RC's Bully2 / SuDu 3D Build
Got another part done today lol, there's the rear beadlock rings.
Still working on lighting the fronts, thanks to some great input and a lot of cad design work they should be done very soon [/URL]
[/URL]
Though this one in just because I like looking at it.
[/URL]
ROCKCRUISER is offline   Reply With Quote
Old 06-21-2016, 06:56 PM   #42
Hey it's me again, Got an update on the two pcs shocks, THEY WORK!
Anyway I went thought about 8 different internal tube designs and bench tested them as best I could. Ended up with a shock that works really well.
So I'm onto making four total mounting them on a rig and hitting the rocks.
But right now they cycle fully are easily bleed, super smooth with no hard spots/dead spots in them.
1st test is going to be with 50wt shock oil, then 70wt dif oil.
Still working on the over all weight, I'd like them to be 10grams total.
May need a tester or two lol.
[/URL]
[/URL]
[/URL]
Thanks for looking!
Old 06-21-2016, 06:59 PM   #43
I would be honored to test them!
The wheels too!
travis c. is offline   Reply With Quote
Old 06-21-2016, 07:05 PM   #44
The wheels too!
Finalizing everything hopefully before Rausch, so I'm probably about a good month away from having anything available, but I'll PM you as soon as the parts are ready.
Old 06-21-2016, 07:24 PM   #45
Awesome,looking forward to checking them out!
If I end up liking them, I'll run em down at Apple Valley in September at the comp.
Thank you ROCKCRUISER!
Old 06-25-2016, 09:08 PM   #46
Got the first of many goodie bags going out to a close friend tomorrow!
Give them a good thrashing Mr. Crawlinghulls!
[/URL]
Old 06-25-2016, 09:19 PM   #47
So I've been working on getting all my parts as light as possible.
Here's some of the reworked parts."
Front beadlock inner rings for internal weight system. My first design weighed in at 14 grams.
[/URL]
Rear beadlock inner ring or both with no internal weight just beadlock.
[/URL]
Smaller OD front inner ring for internal weight system, allowing for more foam tuning.
[/URL]
New Bully 2 Hub with a 14mm pin instead of 10. The old hub weighed in at 18grams. This new hub get me at 10 3/4 before mounting tires on my rims.
[/URL]
Old 06-26-2016, 04:57 AM   #48
crawlinghulls is offline   Reply With Quote
Old 06-26-2016, 08:07 PM   #49
Just a little update, got a new steering arm made today along with a couple king pin bushing, one 2mm longer & a one 3mm longer depending on what size carbon fiber I use to make the steering arm.
[/URL]
[/URL]
[/URL]
HERE'S A LITTLE TEASER, WHATS THAT!
[/URL]
Wouldn't the arm (being bend inward) stuff the ackeman of the steering geometry?
Colgout is offline   Reply With Quote
Old 06-26-2016, 10:28 PM   #50
? Not sure I follow, this set up uses a shorter tie rod and gives better contact for a steering stop as not to allow oversteer in hard binds.
This is just a prototype right now making a few different offset from a 2mm all the way to this 6mm, then testing see what's better.
Not sure I awnsered your question lol, but here's a better pic
[/URL]
Old 06-28-2016, 11:08 AM   #51
Just cut some sweet CF rings, straight from the mind of Mr. Crawlinghulls.
This is his set to go with those nice beadlocks.
[/URL]
[/URL]
[/URL]
Old 06-28-2016, 05:33 PM   #52
Next project the rear axle? Carbon fiber tubes in red & black along with some grade 5 Titanium, dropping weight.
[/URL]
[/URL]
[/URL]
Old 07-01-2016, 06:50 PM   #53
Update with more parts I just made, hot off the press. Some Grade 5 Ti or 6AL-4V Titanium
[/URL]
[/URL]
[/URL]
Setting up lol
[/URL]
Saved about 13 grams just in the rear shafts, still think I could lighten them a little more.
Old 07-01-2016, 07:11 PM   #54
Made up a set of front wheel faces for my beadlocks, what you think?
They came out weight in at 5 grams.
[/URL]
A little update on the front beadlock weight system to.
Originally they weight in at 38 grams with nylon standoffs & al hardware.
The new recut lighten versions come in at 30 grams.
[/URL]
The rear beadlocks are at 12 grams with nylon standoffs & al hardware.
[/URL]
Old 07-01-2016, 08:04 PM   #55
Nice work on the rig so far. Looks like a lot of fun. What is the OD of the largest part of your weight system? I tried 4 3/8" with delrin. Wanted to try CF and never got to it. The ackerman thing is going to be weird. Outside wheel is going to turn sharper than the inside. If it ends up being a problem flip them over and run a longer rod. Very nice work on the carbon fiber parts! Good to see someone making their own parts.
josh6575 is offline   Reply With Quote
Old 07-01-2016, 08:45 PM   #56
Thanks, right now I made 3 different size Internal CF rings/beadlocks
3 1/2 is the biggest then 3 3/8 and a 3 1/4 for a friend to try.
1st size I'm going to give a try is 3 1/2 leaves just enough room for foam, maybe.
Still working on the weight holder, did a redesign on this week need to cut a few new ones. Changed the way the weight is mounted more options.
As for the steering arms have to wait until the rigs up and running so I can get some testing in. Then changes will happen or I'll make a whole new knuckle lol.
Thanks again
Old 07-01-2016, 08:57 PM   #57
Custom Carbon Fiber
Robbob's Avatar
Thats impressive, its just as light as our C-class and its a beadlock. Interested to see how well the carbon holds up Nice Job!
Robbob is offline   Reply With Quote
Old 07-02-2016, 05:51 AM   #58
Off the charts!!!!!! Beadlocks Baby
Old 07-02-2016, 08:58 AM   #59
[/URL]
[/URL]
[/URL]
What did U use to bond the CF tubes To the Aluminum parts
Tom G is offline   Reply With Quote
Old 07-02-2016, 09:28 AM   #60
Sorry that pic was just for show, there's a new shot!
I didn't get to fancy with the hole locations just did it by hand.
I'm probably going to make Delrin axle tubes cut in half to go with the CF tubes.
All the work will be done on my CNC 7 axis lathe.
So hole locations will be the same on all sets.
3M does make a really good adhesives for CF to metal. I'll give it a try later on but for right now I'm going to run the 3mm screws.
[/URL]
RC's Bully2 / SuDu 3D Build - Similar Threads
Dlux/sudu build FLOKI-81 EnRoute Berg 162 06-17-2016 12:28 PM
Hustler's Sudu Build stankulas Axial AX-10 Scorpion 13 05-09-2015 07:11 PM
Looper's Bully2 Build Looper RC4WD Bully 19 10-10-2014 07:35 PM
Papabash's Bully2 Build papabash RC4WD Bully 54 05-16-2011 08:54 PM
