07-25-2016, 08:34 PM | #81 |
Rock Stacker Join Date: Jun 2016 Location: Southern California
| Re: RC's Bully2 / SuDu 3D Build
It's all Grbl to me. |
07-26-2016, 05:53 AM | #82 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
NEO is the one |
07-26-2016, 06:52 AM | #83 |
Pebble Pounder Join Date: Mar 2008 Location: Wallingford, CT.
| Re: RC's Bully2 / SuDu 3D Build |
07-26-2016, 06:56 AM | #84 |
Rock Crawler Join Date: May 2007 Location: Norwich
My name is Neo
07-26-2016, 03:41 PM | #85 |
07-28-2016, 07:40 PM | #86 |
| Re: RC's Bully2 / SuDu 3D Build Shock update! Onto Rev. B ok so I added a 3 pack replaceable o-ring pack. The bottom screws in up against a inner stop that captures the inner sleeve that's interchangeable to control the flow rate. Put two together no leaks. Next I'm going to add an o-ring to the bottom to remove the need for thread seal and then finally I'm going to make some Ti shafts for them. |
08-03-2016, 12:40 AM | #87 |
DravTech Join Date: Aug 2012 Location: Sweden
There is so much awesome stuff going on in this thread. I cannot wait for more |
10-19-2016, 11:22 AM | #88 |
Pebble Pounder Join Date: Feb 2013 Location: Mount Olive, AL
Hey just wanted to let you know, 3m makes panel bond that is a 2 part epoxy and it's great! I do paint and body work for a living and we use it a lot and on everything, metals plastics and cf too and it bonds great and holds up great! You have to use the slow cure one though, the fast curing version doesn't bite as well. The part number is 08115 and it is very good stuff! Awesome build also!
06-19-2017, 09:27 PM | #89 |
Newbie Join Date: Dec 2016 Location: barberton
did you change anything with the vvd's in the front axle and are you making the Ti rear shafts for sale? If you are please pm me
06-19-2017, 10:57 PM | #90 | |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: RC's Bully2 / SuDu 3D Build Quote:
You never mentioned what these are? | |
03-09-2019, 12:04 PM | #91 |
Quarry Creeper Join Date: Nov 2011 Location: IN A HOUSE
What ever happened to this build ? This is a awesome thread!!!
RC's Bully2 / SuDu 3D Build - Similar Threads | ||||
Dlux/sudu build | FLOKI-81 | EnRoute Berg | 162 | 06-17-2016 12:28 PM |
Hustler's Sudu Build | stankulas | Axial AX-10 Scorpion | 13 | 05-09-2015 07:11 PM |
Looper's Bully2 Build | Looper | RC4WD Bully | 19 | 10-10-2014 07:35 PM |
Papabash's Bully2 Build | papabash | RC4WD Bully | 54 | 05-16-2011 08:54 PM |
