12-18-2016, 05:35 AM | #41 |
Rock Stacker Join Date: Jun 2016 Location: vienna
| Re: bully2 build from czech republic |
12-18-2016, 05:38 AM | #42 |
the build is now ready, time for testing the electronics, soldering was awful hope i didnt screw smth Sent from my iPhone using Tapatalk |
12-18-2016, 07:20 AM | #43 |
Bent rod end is the trick Hang up and Drive |
12-19-2016, 02:14 AM | #44 |
firts test of electronics not succesfull need to resolder the connector from escs to battery and rework the settings on my radio a bit, today next try and hope first drive Sent from my iPhone using Tapatalk |
12-19-2016, 02:37 AM | #45 |
12-22-2016, 12:53 AM | #46 |
have small problem with calibration of esc's, can i calibrate them both in the same time or should i do it one by one, esc's are micro sidewinder 2 and transmiter sanwa m11 configured for moa, thanks for tips Sent from my iPhone using Tapatalk |
12-22-2016, 01:15 AM | #47 |
RCC Addict Join Date: Jun 2007 Location: Finland
| Re: bully2 build from czech republic Yes you can. I did calibrate both at the same time. |
12-22-2016, 01:42 AM | #48 |
12-22-2016, 02:47 AM | #49 | |
| Re: bully2 build from czech republic Quote:
12-22-2016, 05:38 AM | #50 |
And if they won't calibrate together, do them one at a time. Holmes notes this on esc with shared battery connections(smashed) Hang up and Drive |
12-22-2016, 09:12 AM | #51 |
Pebble Pounder Join Date: Oct 2016 Location: Weatherford
I calibrated mine together have dual smashed micros and an mt4 tx with 92744 rx and 461 rx
12-22-2016, 09:22 AM | #52 |
my tx is old M11 from airtronics but i found a guide on rccrawler how to setup it, but still the esc's are not willing to calibrate, tonight next try Sent from my iPhone using Tapatalk |
12-22-2016, 09:22 AM | #53 |
and thanks for tips and infos Sent from my iPhone using Tapatalk |
12-22-2016, 10:20 AM | #54 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Did you try one esc at a time? Every setup is different, some will calibrate together but others need each one calibrated separately. Plug one into channel 2 then calibrate it, then unplug it and plug 2nd esc into channel 2 and calibrate it then hook every back up like normal and they should both work.
12-22-2016, 10:25 AM | #55 |
this is my plan for tonight Sent from my iPhone using Tapatalk |
12-22-2016, 01:47 PM | #56 |
success, finally i managed it, over weekend will be first run Sent from my iPhone using Tapatalk |
12-22-2016, 03:03 PM | #57 |
Do you have adjustable speed on one motor ?? I have a separate mix and underdrive in the rear is so valuable Hang up and Drive |
12-22-2016, 11:12 PM | #58 |
no i dont have will think about Sent from my iPhone using Tapatalk |
12-23-2016, 12:08 AM | #59 |
the question is how to do that? on tx? or motor itself? Sent from my iPhone using Tapatalk |
12-23-2016, 01:20 AM | #60 |
Depends what setup is on your m11 for my mt4 it has a Moa setting sometimes with older rx you can manually program or just adjust with trim settings
bully2 build from czech republic - Similar Threads | ||||
RC's Bully2 / SuDu 3D Build | ROCKCRUISER | RC4WD Bully | 90 | 03-09-2019 12:04 PM |
Looper's Bully2 Build | Looper | RC4WD Bully | 19 | 10-10-2014 07:35 PM |
RC 4x4 expedition videos from Czech Republic | jerabekj | Chit Chat | 4 | 01-03-2012 12:52 PM |
Papabash's Bully2 Build | papabash | RC4WD Bully | 54 | 05-16-2011 08:54 PM |
