08-19-2016, 04:36 PM | #1 |
| Two
That's all...... More to follow.......... |
08-19-2016, 04:51 PM | #2 |
| Re: Two
Yup a virgin ! But not for long......... |
08-19-2016, 08:04 PM | #3 |
RCC Addict Join Date: May 2011 Location: at home
| Re: Two
check the oil and the air pressure, there is a thread from one of the pros where he went over one of these. he mentions several things to look for like loose screws, maybe not enough grease, oil missing from the shocks, potential problems with the routing of the wires, etc.. damn but it sure looks nice. enjoy |
08-19-2016, 09:18 PM | #4 |
| Re: Two
Did put a battery in and it is rtr. Found 3 loose screws already. Am planning a strip down, check , adjust and learn tomorrow. I do know it needs the motor wires moved, I need smaller batteries, and it is totally off the wall !! I've read a dozen threads on setup, the tx/rx is s pain, but I will get it |
08-19-2016, 09:28 PM | #5 |
| Re: Two
I bought a set of axles when they first came out. slick smooth sexy but a kit sounds tempting but so does the rtr. I can always change out the esc later I prefer having 2 escs. is that radio 3 or 4 channel? or heavens forbid only 2? |
08-19-2016, 09:46 PM | #6 |
| Two
It's 4 the dig unit really works well off front switch 3. I looked for the 100 difference for motors, esc, bec,dig,tx/rx.....great deal It is so quiet and smooth, the tx is cheap feeling, servo is ok , but have a 400 oz coming soon. Knuckle weights are no where to be found. I am having a blast so far! Last edited by mikemcE; 08-19-2016 at 09:49 PM. |
08-19-2016, 10:21 PM | #7 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Two
DEFINITELY do a full tear down, both axles all the way down, loctite every bolt on axles. There was screws loose, barely any loctite used on axles, no grease, and motor pinion was barely contacting the gears inside.
08-19-2016, 10:28 PM | #8 |
Rock Stacker Join Date: Jun 2016 Location: Beaverton
| Re: Two
Nice move. Vent the tires. Servo is a nice upgrade. Controller is cheap feeling but works just fine for single esc. Softer springs all around. You can add oil but only up to about half inch from full. It fits seem to dampen them a bit and help some. Clock the axles a bit more with longer rod ends
08-19-2016, 10:59 PM | #9 | |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
| Re: Two Quote:
If you want the toggle switch to be your dog switch plug channel 3 into channel 4 channel 3 is the back switch by steering wheel Sent from my iPhone using Tapatalk | |
08-20-2016, 06:57 AM | #10 | |
| Two Quote:
4 sets in box , how do I tell? What ends do I need? Jato? Aluminum? Shocks will be 1/2 filled with 30w and 50w to start Vent tires not wheels ?? I'm still new to crawling Last edited by mikemcE; 08-20-2016 at 02:57 PM. | |
08-20-2016, 06:58 AM | #11 | |
| Re: Two Quote:
Did That ! Last edited by mikemcE; 08-20-2016 at 01:01 PM. | |
08-21-2016, 09:20 AM | #12 |
| Re: Two
After minor setbacks , I'm waiting on my Holmes BR mini, but old reliable sct is working for now. Time to play and tune! |
08-21-2016, 05:03 PM | #13 | |
| Re: Two Quote:
I vented the tires with a leather punch. 4 holes symmetrically across from each other using the 5/64th punch size. | |
08-22-2016, 01:06 PM | #14 |
| Re: Two
Jato ends #5525R. Do I add them to upper links, to lift motor up? |
08-22-2016, 01:27 PM | #15 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: Two
Yes rear uppers
08-22-2016, 01:36 PM | #16 |
| Re: Two |
08-22-2016, 02:07 PM | #17 |
| Re: Two
Just rear. Front isn't needed.
08-22-2016, 07:04 PM | #18 |
| Re: Two
Did the rod ends, went down one hole, dropped shock mounting on the axle and the other end moved down also.back almost collapses now it's so soft
08-23-2016, 05:32 AM | #19 |
| Re: Two
Pics of the new servo $80.00 |
08-23-2016, 08:31 AM | #20 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: Two
Love the servo 149 r/c worx team driver |
