09-13-2016, 03:56 PM | #21 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: 1st Comp Rig - Bully RTR
With the krazed builds tungsten holders, I was able to fit 9 slugs and is 4.70oz each side. Lol. So later on if you want another option, definitely look into it. You can run 1-9 tungsten to get what you want and all of that weight is low, all at center axle line and below.
09-13-2016, 04:25 PM | #22 | |
Pebble Pounder Join Date: May 2016 Location: Warwick
| Re: 1st Comp Rig - Bully RTR Quote:
Sent from my HTC One_M8 using Tapatalk | |
09-13-2016, 04:38 PM | #23 |
Yes. But depending how wide your hubs are, you might not be able to run 9 but 6 for sure. I added slw spacers to stock hubs.
09-13-2016, 04:49 PM | #24 | |
09-13-2016, 06:17 PM | #25 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
If you go to the Krazed build website and find the hangers he has a link for the weights there they are weights for pinedurby cars |
09-13-2016, 10:31 PM | #26 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
| Re: 1st Comp Rig - Bully RTR These are prototypes and for dlux style wheels.. But also for Tungsten slugs Verstuurd vanaf mijn Nexus 6P met Tapatalk |
09-14-2016, 07:00 AM | #27 |
appreciate the recommendations and wondering if both these systems completely replace the rc4wd weights or can be used in conjunction with them? Sent from my HTC One_M8 using Tapatalk |
09-14-2016, 07:31 AM | #28 |
They replace the system... 2 rc4wd weights are only 50g six of these tiny weights are 91g.. And way lower.. Verstuurd vanaf mijn Nexus 6P met Tapatalk |
09-15-2016, 09:06 PM | #29 |
So I set my micro 2's and put them together but didn't smash them completely and also ordered some J Concepts. I decided to take her out another time before changing out the hobbywing esc's which are working pretty good btw and don't get hot at all but weigh about 75-80g combined. Anyway I seen some rocks driving home from a park the other day which is less than 10min away from my house and decided to run there tonight because it's in the back of a store strip parking lot. Anyway to my surprise there were a lot more rocks so don't get jealous hah jk Sent from my HTC One_M8 using Tapatalk Last edited by THX_138; 10-16-2016 at 02:13 PM. Reason: Grossly oversized images |
09-17-2016, 08:28 AM | #30 |
Rock Stacker Join Date: Sep 2016 Location: Nor-Cal
Sweet crawling spot. I have to find me one like that.
09-17-2016, 08:34 AM | #31 |
RCC Addict Join Date: May 2012 Location: Folsom
Very nice! And its lit up for night practice!
09-17-2016, 01:57 PM | #32 |
| Re: 1st Comp Rig - Bully RTR |
09-17-2016, 08:31 PM | #33 |
I wanna be Dave Join Date: Dec 2006 Location: here
09-18-2016, 10:06 AM | #34 |
Lookin good, time for pink springs all around since losing all that chassis weight. What 500 size battery did you go with? And how much softer is the front end with the shocks like that?
09-18-2016, 10:18 AM | #35 | |
09-20-2016, 10:08 AM | #36 |
Whats the charge rate on those gforce batterys?
09-20-2016, 10:17 AM | #37 |
If you think you have to much flex. Limit the shocks with internal or external spacers on the shock shaft. Don't add stiffer springs to limit articulation. Just my 2cents Last edited by tapped-out; 09-20-2016 at 10:21 AM. |
09-20-2016, 10:24 AM | #38 |
09-20-2016, 01:54 PM | #39 | |
Thank god, if you said 1C I was going to pass lol. Im going to order some then. Thanks. | |
09-20-2016, 02:31 PM | #40 |
| Re: 1st Comp Rig - Bully RTR Thanks for the tip and I will be testing it out the next couple weeks with different setups and will definitely keep this in mind.
