Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: 1st Comp Rig - Bully RTR
Old 09-20-2016, 03:21 PM   #41
Default Re: 1st Comp Rig - Bully RTR
Originally Posted by 84yoda View Post
Internal for sure. I'll probably limit my fronts a little. Rear is already limited since it hits the rear cross support and links.
Thank god, if you said 1C I was going to pass lol. Im going to order some then. Thanks.
I charge my batters like this.. if it's a 600mah I'll charge @ .6A if it's a 450mah .5A, if it's a 5000mah 5.0A ect. Takes about 40min a battery..
tapped-out is offline   Reply With Quote
Old 09-20-2016, 06:02 PM   #42
Mounted the Ruptures up with out any mods other than some air holes and running CI foams. Now I'm about to go test them out a bit on my new found spot!
BTW that's ummmmm not my nail polish back there.....
Sent from my HTC One_M8 using Tapatalk
Xtacy33 is offline   Reply With Quote
Old 09-20-2016, 06:07 PM   #43
Default 1st Comp Rig - Bully RTR
Are they that much wider than the stock bully's ?
I have a set on some wide proline wheels for my yeti. One of my favorite gripping tires down here , I was thinking
HANG UP AND DRIVE !
mikemcE is offline   Reply With Quote
Old 09-20-2016, 06:12 PM   #44
HANG UP AND DRIVE !
Here are a few pics:
Old 09-20-2016, 08:37 PM   #45
Stock foams and wheels ?
Now I want to switch up !!
HANG UP AND DRIVE !
Old 09-20-2016, 09:10 PM   #46
Don't know what that last message was from me but definitely was a mistake. I have CI foams and the stock wheels there.
Old 09-20-2016, 09:32 PM   #47
What do they measure for height? Huge difference from stock but they need some narrowing, they probably rub a lot on the links. Added height will make a big difference, I cant wait to get some taller tires.
84yoda is offline   Reply With Quote
Old 09-21-2016, 06:08 PM   #48
Just under 6" and they do rub at the moment but not as bad as I thought they would. I couldn't get a true comparison because the rocks were damp and the wheels were damp from some wet grass/dirt. Felt they were performing better but also felt like I was flipping over a little more. I still need a knuckle weight system and will be working on that which should help a lot.
Also wondering about my front not seeming like it's able to truly get the rear up and seem to do a fair amount of hopping. Have to try and get some video or something.
Old 09-22-2016, 10:28 PM   #49
Added these weights on for the time being because I'm not ready to buy new wheels yet for other weight options and already have backordered rc4wd weights waiting on towerhobby with using tower cash so basically free.
Old 09-23-2016, 04:44 AM   #50
Only rub is on the battery..... big tires !
HANG UP AND DRIVE !
Old 09-23-2016, 01:17 PM   #51
Ya I have run with stock tires and small batt lol so did you make that weight system
jdmguy760 is offline   Reply With Quote
Old 09-28-2016, 03:39 PM   #52
Here is a vid of some recent local rocks. I'm still learning to drive and don't think I had any knuckle weights at all on the rock wall shots. Added some before taking on the big rocks the other day. First time shooting any kind of rc vid with my phone too
https://youtu.be/_Ehd3TJb-UE
Old 09-28-2016, 04:46 PM   #53
What foams did you use...tires look really stiff?
Id send them in for a cut n shut and shave job.
TraskRiver is offline   Reply With Quote
Old 09-28-2016, 05:04 PM   #54
6 DD narrow comp soft in the front and 5.5 narrow med rear and both with a tuning ring. They are new tires/foams and the fronts are soft/breaking in but the backs not quite..... Rig is now about 5lb 5oz with the Ruptures and knuckle weights. Suggestions on cutting/shaving these? Seems some people are running them stock and some are narrowing them from what I've found on here.
Old 09-29-2016, 06:11 PM   #55
Yes I have searched for ruptures narrowed as well but yet to see them done I have a set coming in I'm going to narrow.. And shave the sides down. My idea was to remove all the smaller center blocks and possibly the inside tips of the larger blocks? To take 1/4-1/2 inch out of the centres. And the second set just shave the side walls and see which is the better option.
tnt-salvage is offline   Reply With Quote
Old 09-30-2016, 10:48 AM   #56
Since you have a plan in place already... Please let me know what you think after you try them out!
Old 10-01-2016, 01:18 AM   #57
Will do, just herd today from hobby shop I won't have them for another week or so. Which is fine as the two bully's are no where near finished. Still waiting on parts to arrive. And still have some to order.
Old 05-27-2017, 10:04 PM   #58
So it's definitely been awhile, added a few more to my growing fleet but here are some changes this rig went through. Now to find the time to run it with 2 small children, a wife and busy weekends. At least I'm prepared when the time comes.....
75g rc4wd weights
BlueBird H50C (moved the promodeler to a shafty)
Narrowed and shaved the Ruptures
Printed my own hood (sticker and laminate protectors to underside of lexan-it's taken a small beating so far)
Krazed Builds Aztecs
HH Puller 400s
Aluminum screws in some areas and bored the rear tube some.
Running wt with 3S 500mah is 2069g
Old 05-28-2017, 02:24 AM   #59
snapon boy's Avatar
What is a shady?
149 r/c worx /scalerfab Team Driver
snapon boy is offline   Reply With Quote
Old 05-28-2017, 05:41 AM   #60
Originally Posted by snapon boy View Post
What is a shady?
Gotta luv spellchecker and late nights haha I meant shafty! It also replaced rig with rug thanks, it's been edited
