09-07-2016, 08:41 PM | #21 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: CEEJRC Bully 2
You can pick up a HF scale, they weigh up to 11lbs. I've had one for a while now and has been good. I weigh everything now. Lol. Also, instead of taking apart the escs to desolder and resolder to shorten the wires, you can pick up a pin crimper and servo pins/plugs. |
09-07-2016, 08:55 PM | #22 |
Pebble Pounder Join Date: Feb 2013 Location: Mount Olive, AL
| Re: CEEJRC Bully 2
No they don't tend to run hot, my old ones never did, but as with any electronics they are going to create heat and if they are shrink wrapped together then it's going to hold more heat, these new ones have been running very cool, I've got probably 10 packs thru them so far and they are running great!
09-07-2016, 08:57 PM | #23 |
| Re: CEEJRC Bully 2
A HF scale? What does HF stand for and where did you buy it?
09-07-2016, 08:59 PM | #24 |
| Re: CEEJRC Bully 2
And yea I know the tool you are talking about I've seen one on eBay but ain't they about 20-30$ I want one that would make it a lot easier and be very quick! |
09-07-2016, 09:14 PM | #25 |
| Re: CEEJRC Bully 2
Here it is with the receiver mounted, I need to get some skins for it because on the one side you can see all the wires, the other side looks clean though haha
09-07-2016, 09:17 PM | #26 |
| Re: CEEJRC Bully 2
Clean side
09-07-2016, 09:18 PM | #27 |
| Re: CEEJRC Bully 2
Not so clean side
09-07-2016, 09:31 PM | #28 |
| Re: CEEJRC Bully 2
Top of suspension
09-07-2016, 09:33 PM | #29 |
| Re: CEEJRC Bully 2
Ride height
09-07-2016, 09:34 PM | #30 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: CEEJRC Bully 2
Turn your shocks upside down if you can..
09-07-2016, 09:37 PM | #31 |
| Re: CEEJRC Bully 2
And the flex shot
09-07-2016, 09:38 PM | #32 |
| Re: CEEJRC Bully 2
One more
09-07-2016, 09:43 PM | #33 |
| Re: CEEJRC Bully 2 |
09-07-2016, 09:44 PM | #34 |
| Re: CEEJRC Bully 2
HF is harbor freight. Yes those crimpers are $20 or $30 bucks. The regular one is $20 bucks and the ratcheting one is $30. I went with the regular one for $20 bucks. Been working fine for me.
09-07-2016, 09:45 PM | #35 |
| Re: CEEJRC Bully 2
Yes
09-07-2016, 09:46 PM | #36 |
09-07-2016, 09:51 PM | #37 |
| Re: CEEJRC Bully 2
Thanks, and yea I've got the front on the outside of the mount and the rear is on the inside, I'm going to change it after a run this weekend and see if I can tell a difference from inside to outside
09-07-2016, 10:19 PM | #38 |
| Re: CEEJRC Bully 2
Now I need to get some motors with more power, I see a lot of people running higher turn motors in their bully 2s I'd like to try 20t I think, I've seen some running 13t Not sure what I want but I know one thing I've got to come up with some $$$ because good motors ain't cheap |
09-07-2016, 10:40 PM | #39 |
| Re: CEEJRC Bully 2
Read up on motor, 35t motor is a good motor. 3 slot armature vs 5 slot armature. Example 16t 5 slot armature is close to 35t 3 slot. armature holmes hobbies has great info about motors. Read this from Holmes Hobbies http://www.holmeshobbies.com/blog/?page_id=400 Last edited by tapped-out; 09-07-2016 at 10:43 PM. |
09-07-2016, 10:46 PM | #40 |
