02-06-2017, 09:54 PM | #1 |
Pebble Pounder Join Date: Oct 2016 Location: Weatherford
| 5th dimension dominator chassis
Gonna make a semi build thread I've already put everything together for mock up but gonna break it back down and do the works on the wires and such so for now you can see it in running mocked up mode
02-06-2017, 10:39 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: 5th dimension dominator chassis
Do you know your lower links are in the wrong location?
02-07-2017, 07:00 PM | #3 |
your talking about the front lowers?
02-07-2017, 07:36 PM | #4 |
| Re: 5th dimension dominator chassis |
02-07-2017, 08:33 PM | #5 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
Lowers should be mounted on the skid like how it was sent, all chassis' are sent assembled so there's no confussion on what goes where. You can reverse the skid the other direction if the tongue is in the way.
02-07-2017, 08:46 PM | #6 |
| Re: 5th dimension dominator chassis Last edited by tapped-out; 02-07-2017 at 08:50 PM. |
02-07-2017, 08:50 PM | #7 |
A heat gun and a 5/8 socket can be used too if you want to warm the delrin and roll the tongue up. But I run short front (rolled up) and long rear to help keep the rocks from getting in between the rear links. Just heat it slow, doesnt take much to warm it and warp it. |
02-07-2017, 08:54 PM | #8 |
02-07-2017, 11:14 PM | #9 |
Pebble Pounder Join Date: Nov 2012 Location: Bavaria / Germany
I also bent my tongue,nearly the same like tapped out did it. And you should also try to move your shocks one or two holes to the center of your chassis,then your riding height will be not so high.Or perhaps use shorter rodends at the shocks And if you use longer rodends on your upper links,your gearbox will turn upwards,that helps a lot over edges |
02-07-2017, 11:54 PM | #10 |
Rock Stacker Join Date: Jun 2016 Location: Southern California
I have officially re-boxed mine, as I just too frustrated with trying to get it set up properly. I even thought about listing it in the classifieds, instead, I just moved on to other projects. Sent from my iPad using Tapatalk |
02-08-2017, 06:11 AM | #11 | |
| Re: 5th dimension dominator chassis Quote:
Hey Lee hook up with me I'll set your rig up RTR and get you on the rock Last edited by tapped-out; 02-08-2017 at 07:29 AM. | |
02-08-2017, 07:55 AM | #12 | |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
02-08-2017, 09:26 AM | #13 |
Thanks Matt and Yoda. Sent from my iPad using Tapatalk |
02-08-2017, 10:16 AM | #14 |
Thanks guys yea I've been going back and forth between this and the xr10 and just wanted to see it back in one piece I'm looking at having some time this week and really want to do everything your talking about deff have to switch skid around so that longer is in rear since I have a receiver battery mount from brc. And yea wasn't sure on the links rod ends are probably to long just have to see and tinker with setting a bit deff want it lower and will try the esc on skid might come up with something new for mount who knows
02-08-2017, 10:52 AM | #15 |
Tapped out who did your rear links I like those a lot more than the round version I have
02-08-2017, 11:16 AM | #16 | |
Blue rig Chaotic Crawlers made links no longer doing business. Rig with Clear panels. They are traxxas links I bent them. Last edited by tapped-out; 02-08-2017 at 11:20 AM. | |
02-08-2017, 12:29 PM | #17 |
I like the clear panel links how much would it cost for the bottom rear links like that or would you be able to
02-08-2017, 12:36 PM | #18 |
02-08-2017, 02:54 PM | #19 |
You just have to know the right length of your links,bending is not difficult.... if you try it,you can do it every time in the future!
02-08-2017, 08:25 PM | #20 |
5th dimension dominator chassis - Similar Threads | ||||
The 5th Dimension "Dominator" 2.2m chassis | cboggs | Chassis and Suspension | 27 | 06-12-2017 09:09 PM |
Mammoth's 5th Dimension Dominator Build | mammoth | EnRoute Berg | 20 | 04-17-2016 07:06 PM |
