02-09-2017, 02:50 PM | #21 |
Pebble Pounder Join Date: Jun 2014 Location: North California
| Re: New Bully 2 |
02-10-2017, 05:58 AM | #22 |
Rock Stacker Join Date: Feb 2009 Location: Columbus
| Re: New Bully 2
Yes, sorry I missed that. Good luck!
02-11-2017, 11:56 PM | #23 |
Pebble Pounder Join Date: Oct 2016 Location: Weatherford
| Re: New Bully 2
I used a single fxr esc and a rockster dig unit just fine
02-12-2017, 01:23 PM | #24 |
| Re: New Bully 2
Just finished up the build, waiting for the lipo to show up tomorrow. I have some nanotech 3s 1300s that I use in my oxy 3 helicopter but they are way to big. I will get a couple pics up later of the bully.
02-12-2017, 04:08 PM | #25 |
| Re: New Bully 2 |
02-12-2017, 04:34 PM | #26 |
| Re: New Bully 2 w/Pics
Looking good ! The drag link angle will be an issue. I fought with mine forever and when I added my big knuckles up front I had to fix it. See how mine is parallel and even with the tie rod ? I ended up getting a 1.5" Futaba servo arm. Hang up and Drive |
02-12-2017, 06:26 PM | #27 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: New Bully 2
Clock your knuckles back, put tie rod on top of the knuckles and drag link on top of that and add a 3mm spacer to your drag link. That will fix your crazy angle on that drag link. Edit: also add longer rod ends to your rear links to clock your rear axle up. Last edited by 84yoda; 02-12-2017 at 06:29 PM. |
02-13-2017, 12:47 PM | #28 |
| Re: New Bully 2 What benefit would I get from clocking the knuckles and fixing the drag link angle?
02-13-2017, 02:59 PM | #29 |
Newbie Join Date: Sep 2007 Location: Montreal, Canada
| Re: New Bully 2 |
02-13-2017, 03:24 PM | #30 | |
| Re: New Bully 2 Quote:
By clocking you lift the motor up, that's clearance Clarence . As for the drag link when it's straight it will be smoother, and that's always better. I went to a longer arm and the servo works less and steers better. Any change you make on your rig will make it better or worse. Take your time and fiddle until you are happy, or see something else ! Hang up and Drive | |
02-13-2017, 05:29 PM | #31 | |
02-23-2017, 01:18 AM | #32 |
| Dual ESC
I was going to go the rocker dig route but decided to double up the esc's. Went with 2 hobbywing wp1080's. Both esc power switches were deleted and hardwired (soldered) to save space and weight. The bottom esc fit perfectly between the bottom skid mounts but the corners hit the link rod ends so I had to take off about 3/16 off of each corner of the esc with a bench grinder. As for tx, im running the hacked Gt3c with the dig function's and proportional drive. Last edited by UGLY; 02-28-2017 at 02:27 AM. |
02-23-2017, 01:24 AM | #33 |
| Re: New Bully 2
I made a servo skid plate out of a pencil tin can (not a soda can) and got my rear motor raised by installing the rpm longer rod ends. Last edited by UGLY; 02-23-2017 at 01:38 AM. |
02-23-2017, 01:29 AM | #34 |
| Re: New Bully 2
I wanted an upgrade so I went with the rpm's because I have used their plastic on past models and it always met my expectation. Paired them with some samix stainless steel pivot balls. And here it is, wieght is 2011g/4.43lb Last edited by UGLY; 02-24-2017 at 07:40 PM. |
02-23-2017, 05:14 AM | #35 |
Good move, proportional drive makes a huge difference ! Hang up and Drive |
02-23-2017, 09:32 PM | #36 |
Newbie Join Date: Feb 2017 Location: US
I want a bully too Sent from my SAMSUNG-SM-G890A using Tapatalk |
02-25-2017, 12:02 PM | #37 |
| Re: New Bully 2
What diameter tubing are the chassis cross braces? I want to replace the delrin with aluminum.
02-25-2017, 02:50 PM | #38 |
| Re: New Bully 2
6mm. You need seven 40mm, one 58mm and one 65mm. I didn't do the 8 or 12mm ones. It made a big difference in chassis. The suspension does all the work without chassis flex. |
02-25-2017, 03:30 PM | #39 |
| Re: New Bully 2 |
02-25-2017, 03:58 PM | #40 |
| Re: New Bully 2
I didn't make my own, just bought them.
