02-25-2017, 06:27 PM | #41 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
| Re: UGLY's Bully 2
I like the 420 shocks. |
02-25-2017, 06:35 PM | #42 |
Pebble Pounder Join Date: Jun 2014 Location: North California
| Re: UGLY's Bully 2 It adds 25hp It's a way of looking at that rock and sayin..... hey bud, let's party! Last edited by UGLY; 02-25-2017 at 06:38 PM. |
03-01-2017, 08:17 PM | #43 |
| Re: UGLY's Bully 2
Is the comp rule still 12.5" wheelbase? I cant seem to find any rule updates past 2015 in the rules section.
03-01-2017, 09:45 PM | #44 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: UGLY's Bully 2
Yes, Center axle to Center axle.. (wheelnut)
03-02-2017, 10:20 AM | #45 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: UGLY's Bully 2
Make sure you set it up to 12.5" with shocks fully compressed since thats when its the longest.
03-02-2017, 11:12 AM | #46 |
| Re: UGLY's Bully 2 The rules do not mention fully compressed shocks in the measurement. From what I understand it is measured from ride height. The wheelbase on a standard vehicle is always measured at ride height. I dont think the status quo would change for a scaled down crawler.
03-02-2017, 01:42 PM | #47 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: UGLY's Bully 2 Quote:
Ernie | |
03-02-2017, 03:14 PM | #48 |
| Re: UGLY's Bully 2
From USRCCA rules set https://docs.google.com/document/d/1...it?usp=sharing Wheelbase: is measured from center of axle nut to center of axle nut. The vehicle should be set down on a flat surface by the driver. The front wheel on the side that is being checked, must be pointing straight forward. At that time, the driver will then cycle the suspension through it's complete extension and compression range while the judge measures the vehicle's maximum wheelbase. At any point the vehicle's wheelbase cannot extend beyond the maximum limit of it’s class. All the above procedures must be duplicated on the opposite side. Note: All vehicles will be teched in the same ready to run condition, and set up as the vehicle will be run on the course. If the vehicle's wheelbase is affected by radio control it must be cycled or activated during tech inspection. |
03-02-2017, 04:29 PM | #49 |
| Re: UGLY's Bully 2
Found it in the glossary! thanks
03-10-2017, 02:44 AM | #50 |
| Re: UGLY's Bully 2 Last edited by UGLY; 03-10-2017 at 10:16 AM. |
03-10-2017, 02:46 AM | #51 |
| Re: UGLY's Bully 2 Last edited by UGLY; 03-10-2017 at 10:15 AM. |
03-10-2017, 10:20 AM | #52 |
| Re: UGLY's Bully 2 |
03-10-2017, 10:22 AM | #53 |
03-10-2017, 10:55 AM | #54 |
03-10-2017, 11:23 AM | #55 |
03-10-2017, 01:15 PM | #56 |
| Re: UGLY's Bully 2 Last edited by UGLY; 03-10-2017 at 01:17 PM. |
03-12-2017, 03:51 AM | #57 |
| Re: UGLY's Bully 2
What shocks, tra2660 or 2662?
03-12-2017, 10:14 AM | #58 |
| Re: UGLY's Bully 2
2660 + cap mod. Pink mini T springs f/r. Dlux no pre load spring cups or rcbros sells regular spring cups meant for mini T springs. If you do the cap mod, put the bent rod end up front (ones on stock shocks) and rear use tra2742x. |
03-12-2017, 02:12 PM | #59 |
| Re: UGLY's Bully 2 3mm or 4mm? All these diy's with different size screws. The stock rod ends are 3mm so i'm assuming thats what i need?
03-12-2017, 03:29 PM | #60 |
| Re: UGLY's Bully 2
3mm.
