05-17-2017, 04:15 PM | #21 |
Quarry Creeper Join Date: Apr 2012 Location: So. Cal.
| Re: Cloudswimmer's Bully II Build
Decided to order a better servo horn for my Hitec 7955TG. Its a Robotronic 24T 20/24mm. So are the holes in these for the rod end tapped, and if so what thread size .. M2? Anyone know? Thanks |
05-17-2017, 04:29 PM | #22 |
Yes, and M3.
05-17-2017, 04:41 PM | #23 |
| Re: Cloudswimmer's Bully II Build |
05-17-2017, 04:56 PM | #24 |
Not if the ball is like ~7 mm…
05-17-2017, 08:37 PM | #25 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Cloudswimmer's Bully II Build 9.70mm to be exact. Then round the ends on the pin to fit the gear slot 100%. Once you get in there and see it, you'll understand. And its your choice to do it or not, but dont come back here crying if it breaks. Lol. Better to do it now while your in there then later on, its added insurance.
05-18-2017, 09:13 AM | #26 |
Pebble Pounder Join Date: Feb 2017 Location: Canada
Fellow bully noob here. One thing I just noticed was the nuts that hold the wheels on benefit from a washer. I noticed the nut was carving some meat off the center hole of the wheel, because it's too wide of a hole to begin with. Hope I made sense.
05-18-2017, 10:00 AM | #27 |
| Re: Cloudswimmer's Bully II Build Haven't even taken my wheels off yet, but thanks for the heads up. My other rigs all have washers behind the axle nut. Do you plan on starting a build thread yourself? |
05-18-2017, 09:37 PM | #28 |
Hey guys on these stock shocks, are they ready to go or should I put oil in them. Also should I stick with the springs that are in them to start with?
05-18-2017, 10:07 PM | #29 |
Rock Stacker Join Date: Aug 2013 Location: NZ
you generally dont need oil with internal (droop) springs.
05-18-2017, 10:55 PM | #30 |
But there super bouncy, try it and see if it helps. But only fill it half way. And ditch them ASAP! Lol
05-19-2017, 08:30 AM | #31 |
| Re: Cloudswimmer's Bully II Build But I kinda like the way they look .. they look like the Rancho RS9000's on my 1:1 crawler (course guys have been telling me to ditch those ASAP too, for 20 years now )
05-21-2017, 08:48 AM | #32 |
How come we should ditch the stock suspension? They seem alright to me. Holds the weight up and travels smoothly. Not sure what other features a spring could have to benefit crawling slowly over rocks.
05-21-2017, 08:58 AM | #33 |
When I switched foams, the tires wouldn't stay planted, I was getting lift and rolling. The Big Bores I used gave me more travel and with proper springs really help avoid lift.... might just be poor tuning, but they work better for me Hang up and Drive |
05-21-2017, 10:15 AM | #34 |
Because there bouncy and unpredictable. Once you get some better shocks, you'll realize there garbage. Being constant is key.
05-21-2017, 12:29 PM | #35 |
05-21-2017, 01:13 PM | #36 |
05-21-2017, 02:02 PM | #37 |
| Re: Cloudswimmer's Bully II Build You know anything about the RC4WD King shocks? I have a few pair of em laying around here I bought for a scaler project (90mm), but I have used them for mockup only and have no idea how they work, you think those would be better than the stock Bully II RTR shocks?
05-21-2017, 02:18 PM | #38 |
05-21-2017, 02:22 PM | #39 | |
| Re: Cloudswimmer's Bully II Build Quote:
05-21-2017, 03:18 PM | #40 |
| Re: Cloudswimmer's Bully II Build Yeah they look killer for sure. I also have their previous blue and silver shocks and those things definately suck eggs .. stiffer than raging hormones lol. Probably just gonna get the Dravtech's when the time comes and work with these white ones for now.
Cloudswimmer's Bully II Build - Similar Threads | ||||
Master Basher's second Bully build (bully 2) | Master Basher | RC4WD Bully | 51 | 06-27-2014 09:12 PM |
My second bully build up | ozpall | RC4WD Bully | 11 | 04-10-2012 06:20 PM |
Bully Build - Take Two | xirtic | RC4WD Bully | 44 | 05-26-2010 10:35 AM |
Build a Bully For Under $50 | blue10 | RC4WD Bully | 13 | 09-14-2009 11:23 PM |
my bully build | boostedg60rado | RC4WD Bully | 12 | 07-06-2009 05:31 AM |
