05-22-2017, 03:19 PM | #61 |
Quarry Creeper Join Date: Apr 2012 Location: So. Cal.
| Re: Cloudswimmer's Bully II Build Ok guys group hug time Any of you going to Axial Fest in July? I'll buy ya both a couple beers Last edited by cloudswimmer; 05-22-2017 at 03:21 PM. |
05-26-2017, 06:34 PM | #62 |
Ok just got my package from Amazon with the rest of the stuff I needed to get this project going. One thing in that package is a leather hole punch to vent the tires. A couple people recommended 4 2mm vent holes in the center of each tire (each hole opposite the other to create a cross pattern), but why not put the holes on the inside sidewalls closer to the rim? Seems like I'd be less prone to get sand and dirt in the tires over time, and it would look better?
05-26-2017, 06:42 PM | #63 |
I wanna be Dave Join Date: Dec 2006 Location: here
Some guys put holes in sidewalls, go for it. I know if I did that's where I'd rip the sidewall.
05-26-2017, 06:54 PM | #64 |
| Re: Cloudswimmer's Bully II Build |
05-26-2017, 07:06 PM | #65 |
If your using closed cell foams the water will run out, if using single stage outer, on the circumference to spin out any water This has always worked for me Hang up and Drive Last edited by mikemcE; 05-26-2017 at 07:08 PM. |
05-26-2017, 07:22 PM | #66 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
That's what I did, drilled the rims. 4 total in each rim. But just remember if you put some CI DD foams in, you'll need to put holes in the inner closed cell foams to let the outer foam breath.
05-26-2017, 07:22 PM | #67 |
Ok yeah I can see the reasoning putting the holes smack dab in the center like you did for draining water. Holes on the inner sidewall would require some work getting the water out after a run. I've always avoided water and mud though like the plague, of course roaming around the So.Cal. desert you don't have to work too hard to avoid water and mud lol.
05-26-2017, 08:00 PM | #68 |
I've always had vent holes in center of tires (10yrs) it's never been a problem. And if my foams were to get soaked when I got home I'd remove foams and air dry them. Just put holes in center of tires you'll be fine. |
06-06-2017, 03:30 PM | #69 |
Hey guys, you think there would be any problem running a Sanwa MT4 radio with my Hobbywing 1040 ESC in my Bully?
06-06-2017, 06:08 PM | #70 |
Guys run that radio Airatronics/Sanwa mt4 with dual esc's so if you have that radio it's almost time for 2 esc's. You'll be fine Last edited by tapped-out; 06-06-2017 at 06:14 PM. |
06-07-2017, 02:24 PM | #71 |
06-07-2017, 03:06 PM | #72 |
Pebble Pounder Join Date: Jul 2011 Location: Germany
Castel Micro sidewinder x 2? Smashed and you're done... |
06-07-2017, 03:17 PM | #73 |
06-07-2017, 03:56 PM | #74 |
Quarry Creeper Join Date: Dec 2016 Location: westlerly
Just play around with dig and the hobby wing 1040 for awhile before you go dumping tons of money on it. But Im going to wait till I can afford the HH mini ESC. No need to upgrade right from the get go. Starting to wonder why you bought the rtr at all, haha. Seems like you haven't even driven it and are replacing everything. Maybe I'm just jealous. |
06-07-2017, 04:30 PM | #75 |
| Re: Cloudswimmer's Bully II Build Starting to wonder that myself lol. Actually I had surgery last week and have more coming at the end of this week (oral surgery) so I haven't felt like doing squat .. so to pass the time away I've been laying here studying, planning, buying and staging RC parts for both my Bully and unfinished Wraith. Also been driving my SCX10 Honcho around the house .. I drive it out to the kitchen, my wife puts my meds on it, and I drive it back (using my iPhone on truck for camera and iPad app for monitor) lol Last edited by cloudswimmer; 06-07-2017 at 04:43 PM. |
Cloudswimmer's Bully II Build - Similar Threads | ||||
Master Basher's second Bully build (bully 2) | Master Basher | RC4WD Bully | 51 | 06-27-2014 09:12 PM |
My second bully build up | ozpall | RC4WD Bully | 11 | 04-10-2012 06:20 PM |
Bully Build - Take Two | xirtic | RC4WD Bully | 44 | 05-26-2010 10:35 AM |
Build a Bully For Under $50 | blue10 | RC4WD Bully | 13 | 09-14-2009 11:23 PM |
my bully build | boostedg60rado | RC4WD Bully | 12 | 07-06-2009 05:31 AM |
