02-22-2018, 04:32 AM | #1 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
| Bully 2 ESC setups neede
I just built a Bully 2 and I am doinhg something wrong or is the electronics not compatible.Using 2 hobbywing ESC 1080 series,spektrum 5R radio.Here is the problem:the 2 axles have different rotations,one spining faster then the other one.When reversing,the front axle blocks,I have to push 2 times in reverse so that the front axle unlocks.Don't know where is the problem.Any help is welcome
02-22-2018, 07:03 AM | #2 |
Newbie Join Date: Jan 2010 Location: Cape Cod
| Re: Bully 2 ESC setups neede Hi. My name is Corey and this is my first post on rcc. I just built a bully 2 and researching esc setup. You need to reverse the one that has delay. That one is in reverse/brake when the other one is in forward. Hope this helps. Happy crawling from Cape Cod. |
02-22-2018, 09:07 AM | #3 | |
Quarry Creeper Join Date: Mar 2007 Location: winchester
| Re: Bully 2 ESC setups neede Quote:
are you using the stock dig unit? | |
02-22-2018, 09:15 AM | #4 |
No.I have 2 quicrun 1080 ESC and the TX has a mixing setup for MOA.I also have the DIG unit,but i used them without a DIG unit
02-23-2018, 05:32 AM | #5 | |
You got that right mate.Somebody has messed the setup,when i knew i did it right.Now it's all working.THX again | |
04-09-2020, 07:53 AM | #6 |
Newbie Join Date: Dec 2009 Location: Bristol
I been begging for the same info also! Using my radiolink tx.
05-01-2020, 08:07 PM | #7 | |
Does the "RTR" version come rtr (without lipo) OR fo I need anything else? Thx in advance! | |
05-04-2020, 06:02 AM | #8 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
First make sure that you have pulled one of the red wires from the plug where the ESC plugs into the receiver. Cannot power the RX with two BEC's. Sounds like one of the ESC's is set up for double tap reverse. Like used for bashers. You will need to change the settings to a crawler type reverse.
Bully 2 ESC setups neede - Similar Threads | ||||
3S motor/esc setups? | STANG KILLA SS | Axial Wraith | 27 | 09-24-2013 08:39 PM |
Bully clocked axle pics and setups | craddock35 | RC4WD Bully | 6 | 06-19-2012 05:56 AM |
