01-02-2021, 09:22 PM | #1 |
Pebble Pounder Join Date: Jul 2009 Location: Colorado
| Sticky stock shocks
Aside from swapping them out, is there anything that can be done about the tendency of the stock shocks to stick after sitting for a bit?
01-04-2021, 01:35 PM | #2 | |
Pebble Pounder Join Date: Jun 2014 Location: Central Texas
| Re: Sticky stock shocks Quote:
If you haven't yet, I would probably take them apart, and put a drop or two of shock oil on the shaft and o-rings and cycle them through. You can also run oil in them. I don't use them, instead I have a set of the D-Lux Fab shocks: https://dluxfab.com/Dravtech-short-shocks-p83003157 I use ultra-soft in front, and soft in the rear. I run 20wt all around in the winter and ~40 or 45 in the summer. I'm down in Central Texas, so the summer heat is very hot, and 20wt just wont do anything in that heat. For the ~$80.00 USD investment, I can't think of many other upgrades for the Bully that give you so much performance, and the ability to tweak and tune nearly endlessly. That being said, the stock shocks can be made to work pretty well. Dig through Samu's zero2hero videos where he assembles the shocks and talks about his setup and you'll be on the right path. Good luck! ~Gable | |
01-04-2021, 03:27 PM | #3 | ||
I'm going to take some measurements when I get home to see if I can get the mediums to work. More = Better in my mind (Plus, the mediums are in stock in my color ;) ) | ||
01-04-2021, 04:03 PM | #4 | |
I went with shorts. I had the ~6mm limiters in them, but found it a bit short. I'm going to put in some ~3mm nylon spacers I have on hand to try at some point in the future. I think some folks like a longer shock in the rear especially on the Bully's. You might ask some folks on the Dlux facebook group, as there are lots of bully owners there that are running his awesome shocks. IIRC Erik says he likes a ~3 3/4" shock, with a ~1/4" spacer. The shorts he sells are 92.5mm eye to eye, or 3.64 inches (~3 5/8" approx). The mediums are 106mm eye to eye, or 4.17 inches (~4 3/16'ish). I've bought his cap mod, no pre-load cups, etc. and put those on big bores with mini-t springs. They work very well, cost almost exactly the same. I prefer the Dlux shocks as the bodies are nice and slim, makes them so much easier to fit with good clearance. Cheers, Gable | |
Tags |
just buy dravtech shocks |
Sticky stock shocks - Similar Threads | ||||
shocks became very sticky after oil change | lsone | Traxxas TRX-4 | 8 | 03-29-2018 09:05 PM |
Sticky Shocks | EverettY | Axial XR10 | 10 | 09-18-2012 10:55 AM |
Sticky Shocks | millrtme | General Scale Talk | 10 | 09-16-2010 06:46 PM |
sticky shocks | rippa55 | Kyosho Crawlers | 2 | 01-21-2009 11:00 PM |
